Hikvision DS-7608NI-I2 / 8P Firmware
Maximo101
Jan 7, 2019
80
49
Melbourne, Australia
Hi, I have an DS-7608NI-I2 / 8P which is running V4.1.60 build 180717
I believe i need to install
  • V4.1.64 (Bridge release)
  • V4.22.000 (Database table update)
  • V4.40.010 (Web engine transition)
then final version: V4.60.005 (which i found at which shows the NVR is discontinued)
Does anyone know where i can find the older ones so I can upgrade one at a time to not brick my device?
The official australian site doesnt list the nvr anymore :(
Thanks
I solved this, with the help of AI, Gemini.
Because my nvr is not a grey market one, i was able to download and install the EU multi lingual firmware to bring it up to date, then apply the latest AU one.
Worked great and I am now on the latest firmware for this nvr.
Official Hikvision European Technical Portal (I-Series Directory): Hikvision Europe Portal - I-Series NVR Firmware Directory — This is the primary open repository mirror where the standard multilingual (ML_STD) firmware files, release history, and branch steps (like the V4.1.x, V4.22, V4.40, and V4.60 series) are archived.
