Hikvision DS-2032-I Console Recovery
Yes, I have down graded a camera to 5-2-5-English. I'm just objecting to the fact that CH cameras are banished to single point only solutions and can't join the current software release chain. I guess this is the new normal where companies try to build a moat around their forts.
Yes, I agree with your sentiments.
Though it's fair to say, at least for the cameras, many of the changes on updates have been around trying to do region blocking, trying to inhibit the ability to make small DIY changes for user benefit, improved logon security discouraging the use of original default credentials. Not a lot to do with adding functionality, not a lot to do with vulnerability fixes to protect those who insist on creating remote access without understanding the risk and protection requirements.
But for every new barrier, there are those with the capability to circumvent it.
The region blocking just gets in the way of people who want to make best use of the products, and trips up those who are ignorant of it.
In my view - it does the brand name no good at all.
Excellent point. The brand is being hurt by the current situation. Distribution and branding are a problem when the uninitiated see no difference between a cheap Amazon CH camera that is locked and a "legitimate" supported camera that costs 50-75% more. One way to salvage it would be to directly advertise a premium brand that does have software improvements and security fixes. Not sure I would choose to go with the expensive camera however.
At least there are capable people that are interested in providing some form of solution. Thanks for your support on this forum!
I'm just finishing up a 14 camera farm security system with a mix of v5.25 and and v5.3.0 CH cameras with a US HIKVision 7716 NVR. Hope they all will play nice together.
All, I bricked my DS-2CD2032-i in a special way, or I think it is in an odd way.
Current condition of the camera is that it will
- boot to it's old IP address
- I does not recognize user names used before
- it does not have a web interface running
- I can log into it using 'root' and '12345' via telnet
when I log in I have some basic unix like commands.
I tried to put a VM on my Mac on to the VLAN of the camera, then us the TAR file that was posted to the tread to recover, and I never see the camera try to download from the FTP.
I just tried the Python Scripts but it is erring in Error: "Address 192.0.0.128:69 in use. Make sure no other TFTP server is running." there is not, as I did a ps -ea | grep ftp99683 ttys000 0:00.00 grep ftp
Since I can log in, is there a way to tell the camera to just load the .dav file?
try this form page 2 of this discussion. Was posted by whoslooking originally. This worked for me..
Ok this is covered in this post on how to recover your bricked camera this covers all firmwares upto 5.2.8
See this post.http://www.ipcamtalk.com/showthread....brick+recovery.
Thank you. I read that post and discovered the 'root' user ID, but I do not have the mtd5 & 6 files.
I thought I could just skip that part, and try the FTPD, but this happens, I tried various combinations to get the demon to run in the back ground;
# -sh: -: not found
[1]+ Done(127) - ftpd
# ftpd &.
[1]+ Done(1) ftpd
# ftpd &
[1]+ Done(1) ftpd
So I learned this morning that there is a new twist. my FTP Client (Cyberduck) was connecting, but getting an error.
Could not parse response code.​
Server Reply: ftpd[400]: 550 Error​
550 Error. Please contact your web hosting service provider for assistance.​
Then I went to a shell/terminal session and just did a ftp [email protected] and the unit responded, (no password)
From your thoughts, I have moved along to this point.
  1. The unit has old IP
  2. The unit does not have username and passwords
  3. the unit does have 'root' and '12345' via telnet
  4. the command to turn on the ftp demon on the unit is 'ftp &.' without the ' and DO NOT hit a second enter or the demon closes.
Now the issue is I do not have the MTD files to push. I need a way to get the 5 & 6 which I assume is the web interface, or how to do a DAV load from a command line, do I FTP it, or is there a syntax around the upgrade command.
This does sound very odd.
Can we get a bit more info, as you seem to have shell root access via telnet?
For example from a 2032 (with apologies to all for the long text):
Code:
login as: root
[EMAIL="[email protected]'s"][email protected]'s[/EMAIL] password:
BusyBox v1.19.3 (2014-07-11 11:25:54 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# cat /proc/mtd
dev:    size   erasesize  name
mtd0: 00020000 00020000 "bst"
mtd1: 00100000 00020000 "ptb"
mtd2: 00100000 00020000 "bld"
mtd3: 00100000 00020000 "hal"
mtd4: 00100000 00020000 "ano_ptb"
mtd5: 00080000 00020000 "env"
mtd6: 00080000 00020000 "param"
mtd7: 00100000 00020000 "dpt"
mtd8: 00a00000 00020000 "rcvy"
mtd9: 00800000 00020000 "krn_pri"
mtd10: 00800000 00020000 "krn_sec"
mtd11: 00400000 00020000 "rmd_pri"
mtd12: 00400000 00020000 "rmd_sec"
mtd13: 01800000 00020000 "app_pri"
mtd14: 01800000 00020000 "app_sec"
mtd15: 00400000 00020000 "cfg_pri"
mtd16: 00400000 00020000 "cfg_sec"
mtd17: 01000000 00020000 "dbg"
# df
Filesystem           1K-blocks      Used Available Use% Mounted on
rootfs                    8084      6675      1409  83% /
/dev/root                 8084      6675      1409  83% /
udev                     47716        76     47640   0% /dev
/dev/ubi1_0              20264     10440      8772  54% /dav
/dev/ubi3_0               1300       128      1072  11% /davinci
/dev/ubi4_0               1300        80      1120   7% /config
192.168.1.201:/cctv1 208751288 151548764  57202524  73% /mnt/nfs00
# cat /proc/kmsg
<5>[    0.000000] Linux version 2.6.38.8 ([EMAIL="root@HIK-RD-CI-Frontend"]root@HIK-RD-CI-Frontend[/EMAIL]) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-70) )
<5>[    0.000000] #33 PREEMPT Fri Oct 24 10:46:55 CST 2014
<4>[    0.000000] CPU: ARMv6-compatible processor [4117b365] revision 5 (ARMv6TEJ), cr=00c5387f
<4>[    0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
<4>[    0.000000] Machine: Coconut
<4>[    0.000000] Memory policy: ECC disabled, Data cache writeback
<6>[    0.000000] Ambarella: AHB        = 0x60000000[0xf0000000],0x01000000 0
<6>[    0.000000] Ambarella: APB        = 0x70000000[0xf1000000],0x01000000 0
<6>[    0.000000] Ambarella: PPM        = 0xc0000000[0xe0000000],0x00200000 9
<6>[    0.000000] Ambarella: BSB        = 0xc8c00000[0xe8c00000],0x00400000 9
<6>[    0.000000] Ambarella: DSP        = 0xc9000000[0xe9000000],0x07000000 9
<6>[    0.000000] Ambarella: HAL        = 0xc00a0000[0xfee00000],0x0000e708 9
<7>[    0.000000] On node 0 totalpages: 25344
[snip]
<4>[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 25146
<5>[    0.000000] Kernel command line: console=ttyS0 initrd=0xc0a00000,0x400000 rw root=/dev/ram dbg=0 KRN_PRT=pri RMD_PRT=pri reserved=0xc6500000,0x100000,99 video=amb0fb:720x480,720x480,1,0
<6>[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
<6>[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
<6>[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
<6>[    0.000000] Memory: 99MB = 99MB total
<5>[    0.000000] Memory: 91192k/91192k available, 10184k reserved, 0K highmem
<5>[    0.000000] Virtual kernel memory layout:
<5>[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
<5>[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
<5>[    0.000000]     DMA     : 0xfe600000 - 0xfee00000   (   8 MB)
<5>[    0.000000]     vmalloc : 0xc9000000 - 0xe0000000   ( 368 MB)
<5>[    0.000000]     lowmem  : 0xc0000000 - 0xc8a00000   ( 138 MB)
<5>[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
<5>[    0.000000]       .init : 0xc0008000 - 0xc002d000   ( 148 kB)
<5>[    0.000000]       .text : 0xc002d000 - 0xc04aa000   (4596 kB)
<5>[    0.000000]       .data : 0xc04aa000 - 0xc04dd6e0   ( 206 kB)
[snip]
6>[    0.401388] Trying to unpack rootfs image as initramfs...
<6>[    0.403997] rootfs image is not initramfs (no cpio magic); looks like an initrd
<6>[    0.438788] Freeing initrd memory: 4096K
<0>[    0.441828] [ kernel version:  svn-97978 ]
<4>[    0.441935] mmc0 power register success!
<4>[    0.441977] mmc1 power register success!
<6>[    0.442114] reboot times :1
[snip]
<5>[    0.542288] Creating 18 MTD partitions on "ambnand":
<5>[    0.542327] 0x000000000000-0x000000020000 : "bst"
<5>[    0.546594] 0x000000020000-0x000000120000 : "ptb"
<5>[    0.550410] 0x000000120000-0x000000220000 : "bld"
<5>[    0.554512] 0x000000220000-0x000000320000 : "hal"
<5>[    0.558402] 0x000000320000-0x000000420000 : "ano_ptb"
<5>[    0.562327] 0x000000420000-0x0000004a0000 : "env"
<5>[    0.566609] 0x0000004a0000-0x000000520000 : "param"
<5>[    0.570643] 0x000000520000-0x000000620000 : "dpt"
<5>[    0.574976] 0x000000620000-0x000001020000 : "rcvy"
<5>[    0.579169] 0x000001020000-0x000001820000 : "krn_pri"
<5>[    0.583081] 0x000001820000-0x000002020000 : "krn_sec"
<5>[    0.587349] 0x000002020000-0x000002420000 : "rmd_pri"
<5>[    0.591325] 0x000002420000-0x000002820000 : "rmd_sec"
<5>[    0.595662] 0x000002820000-0x000004020000 : "app_pri"
<5>[    0.599809] 0x000004020000-0x000005820000 : "app_sec"
<5>[    0.604259] 0x000005820000-0x000005c20000 : "cfg_pri"
<5>[    0.608402] 0x000005c20000-0x000006020000 : "cfg_sec"
<5>[    0.612707] 0x000006020000-0x000007020000 : "dbg"
[snip]
<5>[    0.855660] RAMDISK: gzip image found at block 0
<4>[    1.640593] VFS: Mounted root (ext2 filesystem) on device 1:0.
<6>[    1.640808] Freeing init memory: 148K
[snip]
Two parts, looks like the TFTP is being blocked on the @#$@ Windows machine. need to research the firewall rules, as I thought I created one to open up for the app, but see this on the network;
Code:
14:41:06.876932 STP 802.1w, Rapid STP, Flags [Learn, Forward], bridge-id 8000.00:18:0a:53:a4:54.800e, length 4314:41:06.877631 CDPv2, ttl: 180s, Device-ID '00180a53a454', length 92
14:41:06.877681 LLDP, name POE Switch, length 139
14:41:07.231540 ARP, Request who-has 192.0.0.128 (ff:ff:ff:ff:ff:ff) tell 192.0.0.64, length 46
14:41:07.231697 ARP, Reply 192.0.0.128 is-at ac:87:a3:10:52:84, length 42
14:41:07.231721 IP 192.0.0.64.9979 > 192.0.0.128.9978: UDP, length 20
14:41:07.232018 IP 192.0.0.128 > 192.0.0.64: ICMP 192.0.0.128 udp port 9978 unreachable, length 36
With Respect To the information, 'busy box' does not launch.
Code:
[COLOR=#2f4f4f][FONT=Andale Mono](none) login: root[/FONT][/COLOR][COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]Password: [/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]login: can't chdir to home directory '/root/'[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]# cat /proc/mtd[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]dev:    size   erasesize  name[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd0: 00020000 00020000 "bst"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd1: 00100000 00020000 "ptb"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd2: 00100000 00020000 "bld"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd3: 00100000 00020000 "hal"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd4: 00100000 00020000 "ano_ptb"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd5: 00080000 00020000 "env"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd6: 00080000 00020000 "param"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd7: 00100000 00020000 "dpt"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd8: 00a00000 00020000 "rcvy"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd9: 00800000 00020000 "krn_pri"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd10: 00800000 00020000 "krn_sec"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd11: 00400000 00020000 "rmd_pri"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd12: 00400000 00020000 "rmd_sec"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd13: 01800000 00020000 "app_pri"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd14: 01800000 00020000 "app_sec"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd15: 00400000 00020000 "cfg_pri"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd16: 00400000 00020000 "cfg_sec"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mtd17: 01000000 00020000 "dbg"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]# df[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]Filesystem           1K-blocks      Used Available Use% Mounted on[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]mdev                     48896         0     48896   0% /dev[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]/dev/ubi1_0              20264     12624      6584  66% /dav[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]/dev/ubi2_0              20264     12604      6608  66% /dav_sec[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]/dev/ubi3_0               1300        96      1104   8% /davinci[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]/dev/ubi4_0               1300        68      1128   6% /config[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]# cat /proc/kmsg[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>Linux version 2.6.38.8 (wangqian@ipcteam2) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-70) ) [/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>#75 PREEMPT Mon Jul 14 20:15:03 CST 2014[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>CPU: ARMv6-compatible processor [4117b365] revision 5 (ARMv6TEJ), cr=00c5387f[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>Machine: Coconut[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>Ignoring unrecognised tag 0x44000426[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>Memory policy: ECC disabled, Data cache writeback[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Ambarella: AHB       = 0x60000000[0xf0000000],0x01000000 0[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Ambarella: APB       = 0x70000000[0xf1000000],0x01000000 0[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Ambarella: PPM       = 0xc0000000[0xe0000000],0x00200000 9[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Ambarella: BSB       = 0xc8c00000[0xe8c00000],0x00400000 9[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Ambarella: DSP       = 0xc9000000[0xe9000000],0x07000000 9[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Ambarella: HAL       = 0xc00a0000[0xfee00000],0x0000e708 9[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<7>On node 0 totalpages: 25344[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<7>free_area_init_node: node 0, pgdat c04e5c80, node_mem_map c0506000[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<7>  Normal zone: 198 pages used for memmap[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<7>  Normal zone: 0 pages reserved[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<7>  Normal zone: 25146 pages, LIFO batch:7[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>bootmem_init: high_memory = 0xc8a00000[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<7>pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<7>pcpu-alloc: [0] 0 [/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 25146[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>Kernel command line: console=ttyS0 dbg=0 IP=192.0.0.64 MASK=255.255.255.0 GW=0.0.0.0 SERVER=192.0.0.128 video=amb0fb:720x480,720x480,1,0[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>PID hash table entries: 512 (order: -1, 2048 bytes)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Memory: 99MB = 99MB total[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>Memory: 91180k/91180k available, 10196k reserved, 0K highmem[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>Virtual kernel memory layout:[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>    vector  : 0xffff0000 - 0xffff1000   (   4 kB)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>    DMA     : 0xfe600000 - 0xfee00000   (   8 MB)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>    vmalloc : 0xc9000000 - 0xe0000000   ( 368 MB)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>    lowmem  : 0xc0000000 - 0xc8a00000   ( 138 MB)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>    modules : 0xbf000000 - 0xc0000000   (  16 MB)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>      .init : 0xc0008000 - 0xc027d000   (2516 kB)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>      .text : 0xc027d000 - 0xc04c7000   (2344 kB)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>      .data : 0xc04c8000 - 0xc04e6320   ( 121 kB)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Preemptable hierarchical RCU implementation.[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>     RCU-based detection of stalled CPUs is disabled.[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>     Verbose stalled-CPUs detection is disabled.[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>NR_IRQS:224[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>sched_clock: 32 bits at 72MHz, resolution 13ns, wraps every 59652ms[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<2>sched_clock: wrong multiply/shift: 1864135111>>27 vs calculated 3728270222>>28[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<2>sched_clock: fix multiply/shift to avoid scheduler hiccups[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>Console: colour dummy device 80x30[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>console [ttyS0] enabled[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Calibrating delay loop... 351.43 BogoMIPS (lpj=1757184)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>pid_max: default: 32768 minimum: 301[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>Mount-cache hash table entries: 512[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>CPU: Testing write buffer coherency: ok[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>NET: Registered protocol family 16[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Ambarella Coconut:[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>     chip id:                5100[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>     board type:             3[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>     board revision:         10[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>     chip name:              a5m[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>     HAL version:            176869[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>     reference clock:        24000000[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>     system configuration:   0x040004ea[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>     boot type:              0x00000002[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>     hif type:               0x00000000[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>bio: create slab <bio-0> at 0[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>ambarella-spi ambarella-spi.0: ambarella SPI Controller 0 created [/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>ambarella-i2c ambarella-i2c.0: Ambarella Media Processor I2C adapter[i2c-0] probed![/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>ambarella-i2c ambarella-i2c.1: Ambarella Media Processor I2C adapter[i2c-1] probed![/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>i2c i2c-0: Added multiplexed i2c bus 2[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>ambarella-i2cmux ambarella-i2cmux.0: mux on ambarella-i2c adapter[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Switching to clocksource ambarella-cs-timer[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>NET: Registered protocol family 2[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>IP route cache hash table entries: 1024 (order: 0, 4096 bytes)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>TCP established hash table entries: 4096 (order: 3, 32768 bytes)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>TCP bind hash table entries: 4096 (order: 2, 16384 bytes)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>TCP: Hash tables configured (established 4096 bind 4096)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>TCP reno registered[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>UDP hash table entries: 256 (order: 0, 4096 bytes)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>NET: Registered protocol family 1[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Unpacking initramfs...[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<0>Initramfs unpacking failed: junk in compressed archive[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Freeing initrd memory: 4096K[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<0>[ kernel version:  svn-83192 ][/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>mmc0 power register success![/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>mmc1 power register success![/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<1>use default reserved area information![/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>reboot times :2 [/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>msgmni has been set to 186[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>io scheduler noop registered[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>io scheduler deadline registered (default)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>ambarella-uart.0: ttyS0 at MMIO 0x70005000 (irq = 9) is a ambuart[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>NAND device: Manufacturer ID: 0x98, Chip ID: 0xf1 (Toshiba NAND 128MiB 3,3V 8-bit)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<4>ambarella_nand_config_flash: 0x02e00140, 0x02c00140[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<7>Bad block table found at page 65472, version 0x01[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<7>Bad block table found at page 65408, version 0x01[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<7>nand_read_bbt: Bad block at 0x000006000000[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>ambarella-nand ambarella-nand: ambarella_nand_probe: Partition infomation found![/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>Creating 18 MTD partitions on "ambnand":[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000000000000-0x000000020000 : "bst"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000000020000-0x000000120000 : "ptb"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000000120000-0x000000220000 : "bld"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000000220000-0x000000320000 : "hal"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000000320000-0x000000420000 : "ano_ptb"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000000420000-0x0000004a0000 : "env"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x0000004a0000-0x000000520000 : "param"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000000520000-0x000000620000 : "dpt"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000000620000-0x000001020000 : "rcvy"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000001020000-0x000001820000 : "krn_pri"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000001820000-0x000002020000 : "krn_sec"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000002020000-0x000002420000 : "rmd_pri"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000002420000-0x000002820000 : "rmd_sec"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000002820000-0x000004020000 : "app_pri"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000004020000-0x000005820000 : "app_sec"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000005820000-0x000005c20000 : "cfg_pri"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000005c20000-0x000006020000 : "cfg_sec"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>0x000006020000-0x000007020000 : "dbg"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Ambarella MII Bus: probed[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>ambarella-eth ambarella-eth.0: MAC Address[c0:56:e3:6b:fc:21].[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>mousedev: PS/2 mouse device common for all mice[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>ambarella-rtc ambarella-rtc: rtc core: registered ambarella-rtc as rtc0[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>i2c /dev entries driver[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>ambarella-wdt ambarella-wdt: Ambarella Media Processor Watch Dog Timer[ambarella-wdt].[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>TCP cubic registered[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>NET: Registered protocol family 17[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>ambarella-rtc ambarella-rtc: setting system clock to 2016-02-02 09:41:21 UTC (1454406081)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>Freeing init memory: 2516K[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>net eth0: Could not find default PHY in 9.[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>net eth0: Try PHY[9] whose id is 0x00008201![/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: attaching mtd13 to ubi1[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: physical eraseblock size:   131072 bytes (128 KiB)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: logical eraseblock size:    129024 bytes[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: smallest flash I/O unit:    2048[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: sub-page size:              512[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: VID header offset:          512 (aligned 512)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: data offset:                2048[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: max. sequence number:       412[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: attached mtd13 to ubi1[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: MTD device name:            "app_pri"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: MTD device size:            24 MiB[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: number of good PEBs:        192[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: number of bad PEBs:         0[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: number of corrupted PEBs:   0[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: max. allowed volumes:       128[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: wear-leveling threshold:    4096[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: number of internal volumes: 1[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: number of user volumes:     1[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: available PEBs:             0[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: total number of reserved PEBs: 192[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: number of PEBs reserved for bad PEB handling: 2[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: max/mean erase counter: 4/2[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: image sequence number:  615569961[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: background thread "ubi_bgt1d" started, PID 321[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: recovery needed[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: recovery completed[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: mounted UBI device 1, volume 0, name "app_pri"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: file system size:   22837248 bytes (22302 KiB, 21 MiB, 177 LEBs)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: journal size:       1161216 bytes (1134 KiB, 1 MiB, 9 LEBs)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: media format:       w4/r0 (latest is w4/r0)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: default compressor: lzo[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: reserved for root:  1078659 bytes (1053 KiB)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: attaching mtd14 to ubi2[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: max. sequence number:       295[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: attached mtd14 to ubi2[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: MTD device name:            "app_sec"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: max/mean erase counter: 3/2[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: image sequence number:  1832296192[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: background thread "ubi_bgt2d" started, PID 332[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<6>PHY: 0:09 - Link is Up - 100/Full[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: mounted UBI device 2, volume 0, name "app_sec"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: attaching mtd15 to ubi3[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: max. sequence number:       178[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: attached mtd15 to ubi3[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: MTD device name:            "cfg_pri"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: MTD device size:            4 MiB[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: number of good PEBs:        32[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: total number of reserved PEBs: 32[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: max/mean erase counter: 11/8[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: image sequence number:  1756085558[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: background thread "ubi_bgt3d" started, PID 343[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: mounted UBI device 3, volume 0, name "cfg_pri"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: file system size:   2193408 bytes (2142 KiB, 2 MiB, 17 LEBs)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: journal size:       1032193 bytes (1008 KiB, 0 MiB, 6 LEBs)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: reserved for root:  103599 bytes (101 KiB)[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: attaching mtd16 to ubi4[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: max. sequence number:       179[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: attached mtd16 to ubi4[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: MTD device name:            "cfg_sec"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: number of good PEBs:        31[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: number of bad PEBs:         1[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: total number of reserved PEBs: 31[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: image sequence number:  1084786329[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBI: background thread "ubi_bgt4d" started, PID 354[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: mounted UBI device 4, volume 0, name "cfg_sec"[/COLOR][/FONT][/COLOR]
[COLOR=#29F914][FONT=Andale Mono][COLOR=#2f4f4f]<5>UBIFS: journal size:       903169 bytes (882 KiB, 0 MiB, 5 LEBs)[/COLOR][/FONT][/COLOR]
[/FONT][/COLOR]
Thank you for the help.
That's the reason your camera is not booting - no ram file system.
It's held in mtd11 & 12
But it's probably not actually corrupt - you could confirm if it was extracted - it's possibly an inconsistency in what's been used to update the device and the device model.
I have a suspicion it may also be a deliberate misleading message due to applying wrong firmware, or tripping up on 'hardware descriptor block' checksums in mtdblock6.
That's the standard probe for the Hikvision tftp server.
What was the firmware version written on the camera label, and that reported by the web GUI, if you remember it?
A difference usually indicates some seller-installed firmware, if you didn't update it yourself.
A good place to start would be to use the firmware from the first post here:https://www.ipcamtalk.com/showthrea...are-Downgrader-5-3-0-Chinese-to-5-2-5-English
On the face of it - mtdblock5 & 6 do exist. Did you modify them? If so - best put the originals back until the camera is back fully working.
*edit*
The simplest way is to delete all inbound rules for tftpserve.exe then when you next run it, tick both private and public boxes and click 'allow' when the 'Windows has blocked ...' msgbox pops up.
The label is 5.2.8, I tried to install 5.3 as the web site listed DS-2CD2x32 Camera.... oops
*edit*
I did not modify an mtdblocks. I just used the web interface and uploaded the DAV file of of the website..... :(
I will need to find a windows PC. I use a MAC and have virtual Windows Machines, but the latest trace
Code:
tcpdump: WARNING: sw0_pcap: no IPv4 address assignedtcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on sw0_pcap, link-type EN10MB (Ethernet), capture size 65535 bytes
20:26:50.295780 STP 802.1w, Rapid STP, Flags [Learn, Forward], bridge-id 8000.00:18:0a:53:a4:54.800a, length 43
20:26:50.297160 LLDP, name POE Switch, length 139
20:26:50.297306 CDPv2, ttl: 180s, Device-ID '00180a53a454', length 92
20:26:51.014789 ARP, Request who-has 192.0.0.128 (ff:ff:ff:ff:ff:ff) tell 192.0.0.64, length 46
20:26:51.015139 ARP, Reply 192.0.0.128 is-at ac:87:a3:10:52:84, length 42
20:26:51.015162 IP 192.0.0.64.9979 > 192.0.0.128.9978: UDP, length 20
20:26:51.015512 IP 192.0.0.128 > 192.0.0.64: ICMP 192.0.0.128 udp port 9978 unreachable, length 36
The MAC address responding is the NIC of the iMac (ac:87:a3:10:52:84) not the virtual interface of the virtual machine (00:1c:42:25:06:8e)
I will have to grab a real Windows Machine to get the TFTP server to respond to the request, I am going to send the DAV file you suggested, just need the TFTP server to respond.
Thank you for the help, you have a REAL cool deep knowledge of the system of this camera
For anyone trying this on a Mac with Parallels
- Bridge the VM to the Interface
- Windows 10 - Turn off the Firewall
- Windows 10 - change the IP address of the interface
- REBOOT windows 10
Windows will then come up with the 192.0.0.128 address and the TFTP server from HikVision will see that as its address.
For me trying the DAV file that was with the TAR to down grade from 5.3 to 5.2 now has my camera not even getting an IP address.....
Camera is now grabbing DAV files each time it boots from the TFTP server, but never fully boots. Keeps the 192.0.0.64 (or I think it does from my switch).
I tried the DAV files from the 5.3 downgrader,
then from http://www.hikvisioneurope.com/portal/index.php?dir=Product Firmware/Cameras/DS-2CD2xx2/ the V 5.2.3
then the one someone posted a ZIP of 5.2.5
now trying V 5.1.2
What does sadp report?, as your missing something not sure what thought.
But sounds like your in the min-system mode.
Using a Mac in VM is very limited in this.
SADP only sees my other HikVision Camera. The Switch port does not see an IP address from the device, after it goes through the boot up TFTP sequence.
With no IP I can not Telnet to it. I think I saw on a thread someone finding a serial port inside the camera. Might try this, as of right now, I REALLY have a brick.
Thank you for all the help though, been a journey.
I'm having the same problem with a DS-2CD2332.
It's a chinese hikvision witch original had v5.2.8 installed (printed on it's label)
Problem is that it doesn't show op in SADP
Camera doesn't seem to come online and the IR led stays on all the time.
First I used TFTP uodater to load v5.2.5 on the camera, this is working as normal and ends with the message 'system update completed'.
But after rebooting the camera, it still isn't showing op in SADP and IR led still stays on.
Then I tried to use the 'mtd brick recovery guide' but the problem is that I don't have a copy of the original mtd files.
I'm a total noob in using telnet/cute ftp so I'm asking for some help on how to get this camera back online.
I did manage to get some info through telnet/cute ftp and share some pics of it.
Hope this helps to see what might be the problem.
Does this mean that you made some changes to mtdblock5 & 6?
If so, that could be the reason why the camera is not fully booting.
If you can recall the changes you made (presumably the language bytes), grab a copy of what's there and revert the changes, put them back.
It would probably be helpful in terms of clues to the problem to grab a copy of the kernel log.
Either
cat /proc/kmsg
or
dmesg
should work.
From what you've shown - I'm surprised SADP does not show that camera.
Is your PC wired, not WiFi?
Have you tried re-installing SADP? Latest version is 3.x
I'm using a wired connection.
Just tried newest SADP version without succes.
I've bought the camera from someone who bricked it using the wrong firmware, assuming I could solve the problem like I did with my other 2332.
I didn't do the upgrade myself, so I don't have a backup off the mtd files.
I also don't know what the previous owner did to mess up the camera.
I just assumed that I could get ik back up and running because the original firmware is 5.2.8
Seems it's not so simple as the other one.
Been reading up on all the usefull info here on this forum and trying to figure out what to do.
this is what cat /proc/kmsg shows (don't know how to copy/paste it, so I made some pics)
-edited- managed to copy the kernel log, see next post...
Just learned how to copy/paste in puTTy :peaceful:
(none) login: root
Password:
# cat /proc/kmsg
<4>Machine: Coconut
<5>Kernel command line: console=ttyS0 dbg=0 IP=192.0.0.64 MASK=255.255.255.0 GW=0.0.0.0 SERVER=192.0.0.128 MS_ACTION=auto_update video=amb0fb:720x480,720x480,1,0
<6>NR_IRQS:224
<6>sched_clock: 32 bits at 60MHz, resolution 16ns, wraps every 71582ms
<6>Calibrating delay loop... 319.48 BogoMIPS (lpj=1597440)
<6> chip id: 5100
<6> board type: 3
<6> chip name: a5m
<6> system configuration: 0x177804ea
<6>reboot times :1
<6>NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)
<7>nand_read_bbt: Bad block at 0x000007b80000
<5>ambarella-eth ambarella-eth.0: MAC Address[00:0e:99:02:b2:6b].
<6>ambarella-rtc ambarella-rtc: setting system clock to 2004-01-11 00:06:31 UTC (1073779591)
<5>UBI: max. sequence number: 0
<5>UBI: number of user volumes: 0
<5>UBI: available PEBs: 186
<5>UBI: total number of reserved PEBs: 6
<5>UBI: max/mean erase counter: 34/23
<5>UBI: image sequence number: 2066085301
<5>UBI: background thread "ubi_bgt1d" started, PID 320
<5>UBIFS: default file-system created
<5>UBI: max/mean erase counter: 34/21
<5>UBI: image sequence number: 1524267129
<5>UBI: background thread "ubi_bgt2d" started, PID 333
<5>UBI: available PEBs: 26
<5>UBI: max/mean erase counter: 57/54
<5>UBI: image sequence number: 335092668
<5>UBI: background thread "ubi_bgt3d" started, PID 346
<5>UBI: max/mean erase counter: 58/55
<5>UBI: image sequence number: 2085520618
<5>UBI: background thread "ubi_bgt4d" started, PID 359
No ram file system, so no full boot.
Possibly tripping up on mtdblock5 / 6 checksums incorrect.
Or wrong firmware for the model.
The firmware I used is the same I succesfully used to update my other 2332, so I think it must be the mtd files.
Is it possible to copy mtd5 and mtd6 blocks from a working camera to solve this ?
Or is there a way to copy the 'ram file system' ?
