Hello guys,
i need you help because i'm very confused about all the model hikvision has, but i think it is a great techniology so i would like to try to understand which are the differences between the several model starting from my needs.
actually i'm desiging a video surveillance solution for a farmland. this means that in the night there will be very few light, close to zero if not full moon.
so the feature i'm looking are:
for budget reason i would exclude the deepinview series which i undestand should be the best for night vision.
so based on this requirements, what do you advise?
thanks for any comment
regards
- able to see images in very low light condition. i would prefer to don't use camera with white light to keep them hidden; not sure which is the best between darkfighter (X,S), , powered by Darkfighter, Acusense, Ulta and Pro series
- for the point above i would stay on 4MP resolution, no more; higher resolution, bigger sensor, higher light needed in the night so see
- able to use motion detection, region entrance and exiting, people detection, line crossing
- able to manage distances usually in the range 0-20mt
- power over eth (POE)
- turret or bullet camera
regards
