Ok, tried again it with the recommended wiring.
- still nothing
- managed to type a few letters but unresponsive
This is the new wiring as recommended.
- (cut & stripped insulation with a pair of household scissors)
- let me know if that's correct & should work
Also tried swapping red + black cables from the camera. No response in putty.
Tried your recommended 115200 Speed/Baud rate + default 9600 rate. Also no response.
At this point I think the unit is just dead.
- at least I can't access it via putty
The last thing I can imagine would be my dodgy wiring. These TTL connectors seem to be for pins rather than raw wires.
- (I could go extreme and cut off the TTL connectors and splice the cables together)
The system seems to be running since whenever I plug the LAN cable into the NVR - the green light comes on.
Probably a dead unit?
- still nothing
