heathloder
- Jul 8, 2015
- 6
- 1
Is there a general consensus at this point as to which bytes are OK or "best" to modify in order to "balance the checksum"? I noticed that @whoslooking preferred modifying the MAC or Reset codes:
But I would prefer not to play with my MAC address, and for that matter the reset code. I also would prefer not to go against the best practices set forth by those before me. I have seen several other posts that appear to mention that modifying the build date to account for the byte offset works OK, but I was hoping that @whoslooking might specifically chime in and mention whether your opinion on modifying the build date may have changed.
I'm thinking of performing this on about 5 2032 Chinese models that I received with 5.2.5 firmware (in English) - I don't know what version the boxes/stickers have on them. I have 8 other 2032's that all stream over the address rtsp://<username>:<password>@<ipaddress>/Streaming/channels/1 to a ZoneMinder server, but these 5 will not, and I was hoping that I could try other firmware versions (after doing the mtd hack) in order to enable that functionality. The US models that I have are version 5.1.6, and I've seen posts that mention that version being the most functional, so I will probably try that. I would still like to have the ability to upgrade to other English firmwares should this one not work out. I will attempt the mtd hack on the cameras in question on the 5.2.5 firmware. At that point, can I TFTP the 5.1.6 firmware posted by @whoslooking (the "freedom release"), or do I need to use the official English 5.1.6 firmware?
The change can be made in a few different locations, what you must remember is keeping the checksum intact, i found that the build date and serial number played up on some models, but the mac code and reset didn't have any side effects. If you find where else works and the model add to the post,
If the checksum is good it will still boot without bricking, but keep a copy of the mtd file just to be safe.
