Hikivision firmware 5.3.0
I cant break out of "BusyBox v1.2.1 Protect Shell (psh)", but I can avoid it. :-)
Code:
ssh root@<IP of camera> "ash -c 'ls /dav'"
root@<IP of camera>'s password:
ASC16.bin
GBK
IEfile.tar.gz
WebComponents.exe
_cfgUpgClass
_cfgUpgSecPls
Creative!
Have a go with this fragment from an NVR initrun.sh, in particular see if dropbear is running and see if you can unblock it:
echo "-----------------<List the port filtering and flush any. Dropbear always runs, SSH just gets blocked>---------------"
/bin/iptables -L
/bin/iptables -F
# Fix the execute permission just in case
chmod 755 busybox-armv6l
chmod +s busybox-armv6l
cp busybox-armv6l /bin
ls -al /bin
echo "-----------------<Add new Busybox commands to supplement existing>---------------"
/bin/busybox-armv6l --install -s /bin
# ls -al /bin Far too many to list!
echo "-----------------<inhibit the busybox protected shell>---------------"
mv /bin/psh /bin/psh_orig
ln -s busybox /bin/psh
Got distracted by my English
attachment.php
5.3.0 interface.
Here is full command line access. Its a really crude hack, but it works. :-)
Code:
ssh root@[COLOR=#333333]<IP of camera>[/COLOR] "ash -c 'mv /bin/psh /bin/old_psh'"
root@[COLOR=#333333]<IP of camera>[/COLOR]'s password:
BusyBox v1.19.3 (2015-03-20 17:37:48 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
-sh: /bin/psh: not found
# ls /
bin      dav      dev      home     linuxrc  opt      root     srv      tmp      var
config   davinci  etc      lib      mnt      proc     sbin     sys      usr
Just use the Euro site there is no login
thank. but there was a small problem
tftp server launched
Complete file[...\5.30 Downgrader\digicap.dav] transmit
and then nothing happens
Hi! I don't know if it has been said before, but there is an easy way to switch to english language the web menu of your camera. Go to the login web page and the type javascript:chooseLanguage("en") in the address bar of your browser. Repeat if necessary. The only problem is that it's not a permanent solution.
Reactions: Chiny
This won't fix language mismatch issues though if you are using an NVR.
Hi Whoslooking, good job. I can test the modified firmware for you and share the result to you and forum members liked I did for alastairstevenson. The camera is in chinese 5.3.0 now, so it is not useful for me. Thus any test are welcomed even at risk of brick.Best regards
V5.3.0 build 150327 in Chinese is what I got and can't really use it either. Anyone got anything that can make it go back to English? on the tag on back of cam I says 5.3.0
