Hi all...
Any help with this would be really appreciated.
I have an unbranded NVR, with a Herospeed board.
I flashed Uniview firmware on it, for reasons unknown even to myself to be honest.
The problem I now have is that my NVR can no longer use VCA with my IPcams (which are also unbranded Herospeed). When the protocol is set to "private", the NVR cannot connect to the cameras... When it's set to ONVIF, VCA is not accessible.
This was not a problem when using the original firmware, and I'm a bit stuck on what to do about fixing it.
The NVR works, it just seems like the Uniview firmware has a protocol issue with the herospeed cameras when using "private".
This is the original info dumped from my NVR before I flashed it:
Current version: B3631P11C33040
New Pub version: NVR-B3610.31.11.C33040.250717
Inerversion: GNVRV300R006B10D031SP11C33040
Board type: NVR301-16S3-P8
Uboot version: 1.09
Build date: 2025-07-17 17:53
DEVICE_NAME:901_258
DEVICE_SERIAL_NUMBER:210235U-Blanked the rest.
MAC_ADDRESS:2C6F-Blanked the rest
MANUFACTURING_DATE:2023-09-24
VENDOR_NAME:Herospeed
REGION_CODE:IN
BUILD_INFO:NONE
CUSTOMER_CODE:02
TEST_TRACKING_NUMBER:208
E_LABEL_VER:1.3
PROTOTYPE_NAME:NVR301-16S3-P8-DT
I'm now on Unview firmware NVR-B3610.35.48.260701, which is causing the VCA issue.
Is there anything I can do to get back onto Herospeed firmware? I tried one from their website but it wouldn't flash, I think it's because the date was older... Or maybe just completely wrong.
Thankyou!
Uboot version: 1.09
DEVICE_NAME:901_258
REGION_CODE:IN
BUILD_INFO:NONE
CUSTOMER_CODE:02
E_LABEL_VER:1.3
Thankyou!
