Smd776
Thank you for your help. Do I have any other options?That's a pity.
I'd wondered if the camera firmware may have been old enough to have the Hikvision backdoor, so the camera could be reset to defaults and used to extract the NVR password.
But they aren't.
1. Verify by Reversed Email says "No reserved e-mail address exists. You cannot use this way for verification."
2. Verify by GUID - I dont have GUID file
3. Verify by Security Question says "Set the security question first"
So looks like the system was just setup without setting up any recovery options as well.
Is it possible to own grade one of the camera's firmware to get backdoor access?
Also for some reason SADP pulls NVR with 0.0.0.0 ip. Is there away to give it an IP? Maybe DHCP is disabled on the NVR... trying to export security key to see if support would help reset it.
