Help With reboot the Cam
Mar 17, 2026
6
baghdad
Hi everyone,
I’m trying to reboot a camera via SSH, but the device is running a restricted PSH shell where only specific commands are allowed.
Standard commands don’t work, and I’ve noticed some custom commands like appCmd and camCmd, but there’s no documentation available for them.
Has anyone worked with a similar environment or knows how to properly reboot the device in this case? Any tips or known commands would really help.
Could the OP be from a bot account?
: Log into camera and reboot.
: Switch off your house electrical circuit.
: Use a hammer and smash the camera and then fix it.
Do it this order and I'm sure you'll achieve what you want.
I see your point but which “home” are you referring to? We’re managing around 5,000 cameras, so the approach needs to scale properly. I’m not sure the initial idea is practical in this context. Option three might be a better fit, but that could introduce risks or complications on my end. what u think now
for all here these command we must use
Support Commands:
taskShow printPart prtHardInfo
getPreviewStatus setIp setV6ip
setGateway dspStatus outputClose
outputOpen getDebug setDebug
debugLog getIrstate getMtu
camCmd getCamVer getLux
getMcuInfo getMotion getRawdata
setIrcmd setRectFrame updateCamera
setLaserMode getLaserMode setIrMode
getIrMode setBaiguangMode getBaiguangMode
setYTLock InquireFanSwitch StartLaser
CloseLaser LaserMotReset EnlargeCur
ReduceCur SetCur LaserMotDirect
LaserTeleOffset LaserWideOffset InqSwitch
InqCurrent InqCurMotDirect getMcuStateInfo
setFastFocus getTrackStatus getSelfcheckResult
setLdcMode getLdcMode appCmd
ezoomlens_start_t2_test prtLensCurve getLensCurve
getIp gdbcfg {Test1}
{Test2} {Test3} {Test4}
{TestN} {TestY} setAgingMode
getAgingMode setAgingTime getAgingTime
setLensZoomPos getLensZoomPos showKey
showServer showUpnp showStatus
showDefence setLBS setAlarm
cloudService t1 sandbox
psx-redirect redirect cellulardebug
ifconfig netstat ping
ping6 top iostat
mpstat ps reset
dmesg wl iwpriv
setWifiEnable getWifiInfo exit
getDateInfo diagnose diag
help debug
