Help with initialisation of empiretech cameras?
TonyR
Joined
Jul 15, 2014
Messages
17,470
Reaction score
40,691
Location
Alabama
However, despite the necessary connections of Ethernet and 12v pce It’s not powering on.
You are connecting the camera's 12V barrel connector on its pigtail to a 12VDC adapter of sufficient amperage and with center positive ( + ) and collar negative ( - ) polarity?
bigredfish
Joined
Sep 5, 2016
Messages
18,086
Reaction score
50,334
Location
Floriduh
Thats fine
Dont connect it directly to your laptop.
Plug in the power and connect it to your router. Then try to reach it with your laptop on your network at 192.168.1.108 This is the default address fro Dahua cameras
Do you know what the address of your LAN network is? Is it 192.168.1.X? If so you should be able to reach it
biggen
Joined
May 6, 2018
Messages
2,629
Reaction score
2,948
As @bigredfish says, you need to reach the cam on 192.168.1.108. I always temporarily change the IP on my working computer to an address on the same subnet of the camera (192.168.1.x). Then I connect to the camera and configure it's IP address to my network and then set set my desktop back to my network's subnet range.
wittaj
Joined
Apr 28, 2019
Messages
25,681
Reaction score
50,122
Location
USA
My standard post to these questions:
For this camera you will need to use Internet Explorer - not Edge or Chrome with IE tab, but plain ole Explorer. If you use another browser some of the settings won't hold, like tracking time.
The default IP address of the camera is 192.168.1.108, which may or may not be the IP address range of your system.
Unhook a computer or laptop from the internet and go into ethernet settings and using the IPv4 settings manually change the IP address to 192.168.1.100
Then power up your camera and wait a few minutes.
Then go to INTERNET EXPLORER (needs to be Explorer and not Edge or Chrome with IE tab) and type in 192.168.1.108 (default IP address of Dahua cameras) and you will then access the camera.
Tell it your country and give it a user and password.
Then go to the camera Network settings and change the camera IP address to the range of your system and hit save.
You will then lose the camera connection.
Then reverse the process to put your computer back on your network IP address range.
Next open up INTERNET EXPLORER and type in the new IP address that you just gave the camera to access it.
OR use the IPconfig Tool, but most of us prefer the above as it is one less program needed and one less chance for the cameras to phone home or for something to get screwed up.
bigredfish
Joined
Sep 5, 2016
Messages
18,086
Reaction score
50,334
Location
Floriduh
Just in case it helps...
My home network is a different subnet than the default cam 192.168.1.108. When I get a new Dahau cam, I use Dahua Config Tool to initialize and change cam ip address to my subnet. DahuaWiki
Are you saying the Config Tool can see and manage cameras not on the same LAN as the PC/Laptop running the Config tool?
biggen
Joined
May 6, 2018
Messages
2,629
Reaction score
2,948
I prefer to just temporarily change my computer address over installing and using the config tool. It's simple and takes 10 seconds.
I really don't want to install any Dahua software on my computer that isn't really needed.
YMMV
wittaj
Joined
Apr 28, 2019
Messages
25,681
Reaction score
50,122
Location
USA
YMMV
Same. And gets back to what was being discussed in this Post about is the plug-in safe?
If they developed a config tool that can see and manage IP cameras across different subnets, who is to say the actual camera firmware can't be setup to do the same thing....
BuseyCB
Joined
Apr 24, 2024
Messages
35
Reaction score
5
Location
Uk
Quick question here. Can I download the installer and config the camera offline?
wittaj
Joined
Apr 28, 2019
Messages
25,681
Reaction score
50,122
Location
USA
Yes, these cameras do not need internet service, even though you are using a web browser.
None of my cameras are initialized on a computer with internet access.
I use an old laptop set up to the 192.168.1.xxx subnet and initialize and do everything to set up that camera on a stand-alone computer that never touches my network.
BuseyCB
Joined
Apr 24, 2024
Messages
35
Reaction score
5
Location
Uk
Excellent @wittaj So to be clear…
1. Plug cameras into router
2. Go to ip address (does not need to be connected to internet)
3. Config from there
I’ll be using a Mac and have already downloaded the dhua mac installer. I hope I’m not missing anything.
wittaj
Joined
Apr 28, 2019
Messages
25,681
Reaction score
50,122
Location
USA
By plugging the camera into the router, you are now giving the camera access to the internet.
Further the router does not provide the camera power.
It is best to use a POE switch or POE injector not connected to the LAN to provide power to the camera and connect the computer to that.
And these cameras are centered around Windows, so YMMV using MAC lol.
bigredfish
Joined
Sep 5, 2016
Messages
18,086
Reaction score
50,334
Location
Floriduh
A PoE switch on the LAN also allows it access to the Interwebs no?
I just did it using a 12v wall wart, worked fine, and my network appears to not have been taken over by Bolivian hackers
Tinman
Joined
Nov 2, 2015
Messages
1,228
Reaction score
1,530
Location
USA
Also the installer has a built in manual. Just click the button and select help.
bigredfish
Joined
Sep 5, 2016
Messages
18,086
Reaction score
50,334
Location
Floriduh
Ive used the Config tool in the past, but its been years. Didnt recall it being able to see across networks. But logging into the camera GUI is simpler
wittaj
Joined
Apr 28, 2019
Messages
25,681
Reaction score
50,122
Location
USA
True, comes down to the risk one is willing to take.
Top
