- May 6, 2018
- 2,828
- 3,237
I already have the WB set to "Street Lamp" and that tamed some of the yellow. If I leave it set to "Auto" its even worse!First thing I'd tackle is the white balance. Taht sodium lamp is terrible. Move white balance on night settings from Auto to whatever works best for you and removes that yellow colour cast.
I'd also suggest 120th is too slow a shutter. The woman is blurred and the street lamp should have plenty of light. I use a range with 250th (8ms) set as the maximum permittable. I'll post my rear yard camera settings later when I'm at my BI pc, as it works with only a 5w led for illumination.
One cure for blow out would be to lower the contrast a little. You may find 60 is just too strong in that situation.
PS I find the focual point on my 3.6's to be around 16 feet or so. They're very good at distance but not so good close up.
I can take a look at 1/250 tonight but that may give too dark of a picture though. I'll give it a try and see however.
