Feel your pain. Theres more to this IP camera stuff than i realised especially when you start integrating the NvR and i've been in IT/telco for 25 Years.
I got my 1x 2132 and 1x2142s and 2x 2532 cubes working first directly into a router with an SD card and have been running that way for 6 months. Now i'm integrating the NVR one at a time but its on the couch and i fire it up in the evenings and muck around with it before moving it to the site. Its more convenient with a bourbon in front of the telly and i dont bite off camera and nvr integration all in one
Ive got 5.3.3 on the 2142 english red box and 3.3.4 on the 7806ni-e2/p english red box.
Ive got 2132 3mp and they are chinese serial CcH ive yet to fire one of those up and check its seen by the NVR but many here seemed to indicate it would.
1. The flashing thing white then pic there is another feed on here i read with people having that issue. I dont have that issue with my 2142 4mp and 3.3.4 nvr, or the 2142 that is directly into the router in the field.
2. Re the NVR integration. After reading many posts here i took notes and the general concensus to avoid issues was to in the NVr:
1. Disable plug and play set to manual. It causes unexpected issues.
2. I think the default nvr ip address POE network is 192.168.255.x . And so i statically set my camera ip to match the nvr port e.g. 192.168.255.1 port 1 192.168.255.2 port 2. Static ip on the camera takes out all dynamic dhcp issues and simplifies. I think always do this for hosts like cameras/tvs/ printers.
3. I think the NVr might not have run concurrent 192.168.255.1/2/3/4/5 etc on the first port so i lined them up to make it simple and logical 192.168.255.1/2/3/4/5/6.
4. Turn on virtual host so you can access the cameras directly. If your on the same home network you access them via nvr_wan_ipaddress:65001/2/3/4/5/6. You can see that from the camera config page on the nvr as a link. Virtual host is delivered recently not sure exactly but 3.3.4 has it. To access outside you'd need to set port forward of external_routerip:65001 to nvr_wan_ipaddress:65001 for each port.
5. Make sure in the NVR each camera port config has been changed to your camera admin user and passwords.
Thats all ive done so far and it came up straight away been testing and playing around.
You've prob done all that .. i just shared it for others who might be following us.
6. I put a 6tb western digital purple in there which after initialising is recording fine.
Happy to share experiences, swap config, but im only firing it up every couple days when i feel like it.
