Hi, new BI user here. I'm having trouble adding some of my cameras and could use some help. I can't get the video/address-port setup correct to display video.
I have 4 cameras I'm trying to manage. A recently purchased Dahua that has added just fine and working as expected. The others are an older/cheaper Wansview and 2 Foscams. All the cameras are set up on my LAN and can be viewed locally via a browser without a problem. I also have them set up in IP Cam Viewer without problems. But I can't get the video to work in BI for the 3 older cameras.
I'll focus on just the Wansview as I suspect my issue/mistake is the same for all three. I start the camera add process and after entering the general information, click on the Video tab. Select Network IP for device type, and "Configure" button. I've tried both finding the camera with the http:// field empty, or by typing the LAN IP. Both end up with the same issue. I also used the ONVIF Device Manager tool. It finds the Wansview just fine and displays the video.
This is the result of clicking on Find/Inspect,
Opening 192.168.86.43 port 80...
HTTP Get / request...
Failed with HTTP 12029
Opening 192.168.86.43 port 25112...
ONVIF GetSystemDateAndTime
2019-12-16T16:19:15.000Z
Requesting device information...
Manufacturer:
Model:
FirmwareVersion: 00.01.01.0043P1
GetCapabilities...
Querying services
Has Imaging services: /onvif/device_service
Has media services: /onvif/device_service
Has RTP_RTSP_TCP, requesting profiles
first profile is Profile_token1
first source is VideoSource_token1
requesting URI for profile Profile_token1
RTSP URI: /live/ch0
Has Event services: /onvif/device_service
Has WSPullPointSupport
RelayOutputs: 1
InputConnectors: 0
Has Device IO services: /onvif/device_service
AudioOutputs: 1
Has PTZ service: /onvif/device_service
Done
After find, address is , with Discovery/ONVIF port changed to 25112 (port set up in camera). But when I "OK" click out, the camera display shows "No signal, RTSP: 404 not found.
Changing Make/Model from Generic/ONVIF (from Find/Inspect step) to the correct WansView model results in No signal, error 8000274d (refused; check IP address and port) 0
Any help appreciated.
Manufacturer:
Model:
GetCapabilities...
Querying services
RTSP URI: /live/ch0
RelayOutputs: 1
InputConnectors: 0
AudioOutputs: 1
Done
