robross0606
Can you advise how you went about connecting the USB to serial converter to your board with pins? I have everything I need except haven't walked through the steps because the little pins are so darn hard to connect without a harness.I will mention the serial port on my Speco did have pins on it unlike val-ipcam's which didn't. The process was still the same though.
