aristobrat
- Dec 5, 2016
- 2,979
- 3,180
If your NVR has PoE built-in, then it's likely that your cameras are on a separate subnet. You can try temporarily plugging your computer into the NVR. It should be assigned an IP address that is on the same subnet as your cameras and then you should be able to access them directly. I don't know the steps on a Hikvision NVR, but there should be a screen that shows you the IP address of each camera.
