duplo
Getting comfortable
				Why I have trust issues
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
				I used a Wiggy® type tester for many motor and lighting line or load-side wiring "go or no-go" tests (not control side wiring) to check for voltage after opening a disconnect, or breaker or pulling a fuse. But the very FIRST thing I would do, and do it EVERY time, was to test the tester to insure it detected an energized line.![]()
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.youtube.com
It always drove me nuts seeing electrical panels in clothes closets. Thankfully, IIRC that isn't allowed by code anymore.
That’s actually the gas supply from what I can see?That's obviously the hot water outlet.
Correct. It's glowing red hot because electricity is flowing through it; it's providing a path to ground.That’s actually the gas supply from what I can see?
I do not think that a dryer would discolor PVC. A lot of dryer vents are cheap plastic and the was piece is usually plastic. It looks like to me that is the exhaust on a gas water heater! The other PVC is probably a fresh air vent I had to look back to the gas water heater with the glowing gas line to see if it was the same install!Giving the benefit of doubt, it could be the foil HVAC tape stuff. Which in that case is a shitty job but works pretty well in it's application.
Don't think I've ever seen PVC ductwork. Looks discolored/distorted by heat from dryer exhaust. Started out straight and the heat and tension from the flex duct has caused it to bend off to the side. Which probably is why I've never seen PVC ductwork. ; )
Yeah, I don’t think I’ve ever actually used duct tape on ductwork. That would be a mess after it dries on there. Impossible to get that residue off of things.I use duct tape on a lot of things, but on ducts I use the aluminum tape. It does not deteriorate with age or heat.
Operator: "This is 9-1-1. What is your emergency?"
Looks OK to me....limited direct sunlight so the black UV-resistant zip ties are not necessary here!
