mech
Getting comfortable
You're right, the motherboard had the internal graphics set to AUTO (Gigabyte motherboard) which I switched to Enabled. Now my Intel GPU shows up and my Dahua does the same thing you're reporting: BI5 keeps failing the streaming after grabbing a keyframe. Now in Task Manager I see the GPU Engine toggling between GPU 0 -Video Decode and GPU 1 - Video Decode.I just tried Intel hardware acceleration with H.265 again and it was the same result as last time. I get one frame and then the video just freezes until the watchdog timeout restarts the stream, then one frame again.
@mech It looks like you don't even have the Intel graphics adapter (where Quick Sync resides) enabled on your system. BI will be falling back to software decoding on that camera (I know, it would be great if BI actually told you that).
