- Jan 17, 2017
- 18,310
- 30,697
Well, I've discovered a problem..
I mentioned previously that some of the cameras would go black and that I'd randomly click and they'd eventually appear again. Well, I'm thinking that it coming back on was not a result of randomly clicking, and was just a coincidence, because I've been checking and there is a lot of missing footage. It is supposed to be recording constantly by default, but there are a lot of gaps. It appears to be completely random, both with the length of the gap and with the camera that is missing footage.
I've also seen cars driving and completely disappear.
There's definitely something wrong here. I'm just not sure what it is. Hopefully it's not the cabling.
Any ideas?
Hi,
Chances are there is a configuration issue.
You need to be certain the cameras are set to record 24 7. I'm still learning this so I can't readily give a step by step instruction on this from memory.
Also, cabling errors / connection issues are possible - however if the issue seems to be random then I don't think it would be a cabling issue - as typically if we are careful we don't screw up on too many cables.. perhaps just one or 2 - I had to redo a cable connection myself ;-)
When you go to search pick thurdays 10/5/2017 date and you should see a green bar showing the recording times available to review when looking at the OSD after having selected the cameras. You should have the green bar available up to the time you are looking at it showing that the cameras have recordings up to that time.
