Today, I have purchased my last camera, from Andy. The SD1A203T-GN..
Thanks. I have just started learning the system. Until now, I was just buying cameras and build the PC, recently finished most of the wiring, all though I still have two more cameras to install in stucco(hate doing that).
Today, I have purchased my last camera, from Andy. The SD1A203T-GN. This will be in the back, by the patio door and the wedge one, above the Ring doorbell.
Mach very good point along with set zoom markers and other functions as well which you could script. Would be nice to have the disable option in the GUI as well though as it would then open up the option of a workaround to the focus issue for any users that don't want to script or use NVR's only for example.You can disable auto focus via http api commands.
The IR lights on this camera are huge. Are the IR lights visible or is that the camera picking them up?
Shouldn’t need near full zoom at that range. I’m at 80-85% and capturing at 120ft.
*Edit: Sorry, my bad, removed video. Here's screen caps at 120ft at 80% zoom
View attachment 40794 View attachment 40795 View attachment 40796
Yes size wise and user current non visible IR lightsYou can turn off the IR lights if you don't want them on... or you mean size wise?
Im in the same boat. Are there any good cameras that can capture plates that a little more on the smaller size? Or i guess i cant have my cake and eat it too! LolYes size wise and user current non visible IR lights
How can you tell me the command pleaseYou can disable auto focus via http api commands.
