T tmushy Getting the hang of it Oct 17, 2017 98 44 Yesterday at 6:19 PM #1,281 Anyone ever figure out the solution to Error processing request: error: null value in column "id" of relation "plate_reads" violates not-null constraint I ran two fresh install on two different systems, and still same issue
Vettester Known around here Feb 5, 2017 1,088 1,078 Yesterday at 8:46 PM #1,282 tmushy said: I ran two fresh install on two different systems, and still same issue Click to expand... I've installed this on multiple machines for other users and have never seen this error. Are you using the the updated migrations.sql file?
T tmushy Getting the hang of it Oct 17, 2017 98 44 Yesterday at 9:24 PM #1,283 Vettester said: I've installed this on multiple machines for other users and have never seen this error. Are you using the the updated migrations.sql file? Click to expand... This is a fresh install using the script. Iv googled it and others are having the same issue. I'm also using version 6 of blueiris if it makes a difference
Vettester Known around here Feb 5, 2017 1,088 1,078 Yesterday at 9:42 PM #1,284 tmushy said: This is a fresh install using the script. Iv googled it and others are having the same issue. I'm also using version 6 of blueiris if it makes a difference Click to expand... The version of BI doesn't matter. Does your file structure look like this?
T tmushy Getting the hang of it Oct 17, 2017 98 44 Yesterday at 9:44 PM #1,285 Vettester said: The version of BI doesn't matter. Does your file structure look like this? View attachment 235226 Click to expand... Im running in Ubuntu 25 . I have had this working before but it stopped after watch tower did some update to the database. So I started fresh
Vettester Known around here Feb 5, 2017 1,088 1,078 Yesterday at 9:53 PM #1,286 Sorry, but I'm not familiar with Ubuntu
