Hi. I'm using v2.08.09 of the Blue Iris IOS app, and v6.1.1.4 (latest stable) of the Blue Iris system. Since updating my iPhone to IOS 27, the initial screen I'm used to which is the Live View, will not load until I tap on the Clips tab. Then, the login screen comes up, I'm auto logged in and Live View works as expected. Anyone else seeing this, or have a solution for me other than wait until the next app update?
I’ve been running iOS 27 but have not seen this issue.
In the Blue Iris iOS app settings, what do you have set for, “After login, show”? You could try changing that to a different screen and see if it makes a difference.
