forgot the password for DH-NVR1104HS
Mar 5, 2022
10
pak
hi i have
DH-NVR1104HS and i forgot its password. as i bought it from flee market and it came with chinese language then i flashed english language frimware but it still showed brokent interface as shown in posts on this site.​
so i bought hikvisoin dvr. now hikvision dvr is faulty so i wanted to use the dhaua but i do not remember its password. anyone could help me find a way to reset its password.
i do not remember using email or any details for recovery being set when i was fiddling with it.i do not see the jumper for password reset on it.
anyone could help me find those or guide serial console pinouts as it lacks the serial port as this is first gen model .
it has this image.
DH_NVR11xxHS_Eng_V3.215.0000000.0.R.171013
Why don't you sell it back at the flea market? Sure someone will pay some ridiculous amount for it. Then get yourself a new non second hand unit, that will allow you to create your own password that hopefully you won't forget.
