Received the "Parameter Error" when using the new HiTools Delivery application, as well as when I use Microsoft Edge.
Just wanted to report how I have over come the error "Parameter Error" using the Microsoft Edge browser.
There is a plug-in that I used within Microsoft Edge that will emulate Internet Explorer, it is called "IE Tab"
It actually worked.. I was able to successfully save the OSD settings, using the plugin.
In the video, you can see me try to save 1st with the HiTools Delivery application, 2nd with a normal MS Edge Tab, then 3rd with the MS Edge Tab using the plugin. It finally worked with the plugin.
