^^^ I can't lie, I barely understand half of the terms you use...
Coat hanger, I get.
Coat hanger, I get.
Coat hanger, I get. Picture on the other side would help. (outdoors)After some trial and error, I think installing the camera under soffit is probably the way to go.
I looked inside my attic few times, I am not sure how to pull the wire from the soffit into the attic. The attic closed as shown in the picture, at first I thought I could just drill a small hole just enough to fish the wire through soffit using fiberglass but I have no place in the attic to pull from. Looking for some advice please.
Since you have a new tract home, is your development already built out? If not and houses are still under construction, then maybe you can find your model still in the framing stage. That would be extremely helpful to see what's behind the walls to reduce guesswork.
