Firmware for newer dahua cams as well as detailed specs available here
Even though we have uploaded all required firmware's on our International website but still if anyone want to get any firmware of old or new models.. just hit me up ... will glad to help you out
i there i am looking for firmware for DH-SD42212T-HN version 2.400.0000.R.T4.1216.3N.NR
i LOADED A NEWER FIRMWARE AND ptz HAS STOPPED WORKING.
@EMPIRETECANDY
Do you have the updated firmware for IPC-T5442TM-AS ?
Just received another camera from you and it has
System Version V2.800.0000000.0.R
Web Version V3.2.1.736218
My other/older IPC-T5442TM-AS has:
System Version V2.680.0000000.5.R
Web Version V3.2.1.714895
Reactions: EMPIRETECANDY
@EMPIRETECANDY do you have the latest firmware for the HFW4231B-AS?
I have a list of software/firmware I'm looking for if anyone is interested in helping:
Software:
General_SmartPSS-Win64_ChnEng_IS_V2.003.0000000.0.R.190802
EVS:
General_EVS50XX_Eng_V3.210.0000002.3.R.190603
General_EVS70XX_Eng_V3.210.0000002.3.R.190603
NVR:
General_NVR41HS-W_Eng_NP_V3.215.0000000.0.R.190624
General_NVR4XXX-4KS2_MultiLang_V4.000.0000001.1.R.190830
General_NVR5XXX-4KS2_MultiLang_V4.000.0000001.1.R.20190830
General_NVR6XX-4KS2_Eng_V3.216.0000000.1.R.190617
Older Lite:
General_IPC-HX1X2X-Themis_Eng_N_V2.620.0000003.0.R.190910
Lite H.265:
General_IPC-HX2X3X-Rhea_Eng_NP_Stream2_V2.800.0000012.0.R.190808
Eco-Savvy 2.0 IP Cameras:
General_IPC-HX4X2X-Themis_Eng_N_Stream3_V2.620.0000003.0.R.190910
General_IPC-HX5X2X-Themis_Eng_N_Stream3_V2.620.0000003.0.R.190910
Eco-Savvy 3.0 IP Cameras:
General_IPC-HX5X3X-Rhea_Eng_NP_Stream3_V2.800.0000012.0.R.190808
General_IPC-HEAT_MCU_V2.800.00000012.0.R.190807
Ultra IP Camera:
General_IPC-HX8XXX-Eos_Eng_N_Stream3_V2.680.0000000.41.R.181212
Fisheye:
General_IPC-HX8XXX-Nova2_Eng_NP_Stream3_V2.622.0000000.8.R.190812
SD/PTZ:
General_SD-Chen-Nova_MultiLang_NP_Stream3_V2.800.0000000.4.R.190416
General_SD-Eos_MultiLang_NP_Stream3_V2.800.0000000.5.R.190827
General_SD-Mao-Nova_MultiLang_NP_Stream3_V2.800.0000000.10.R.190909
General_SD-Mao-Themis_MultiLang_NP_Stream3_IVS_V2.640.0000000.2.R.180928
General_SD-Yin-Demeter_Internal_NP_Stream3_Intelligent_V2.640.0000000.5.R.180921
2nd Generation HCVR:
General_HCVR7xxx(V2.0)_Eng_NP_V3.210.0001.4.R.20180113
3rd Generation HCVR/XVR:
General_HCVR5x04-S3_Eng_NP_V3.218.0000002.4.R.180704
General_HCVR5x08-S3_Eng_NP_V3.218.0000002.4.R.180704
General_HCVR5x16-S3_Eng_NP_V3.218.0000002.4.R.180704
General_HCVR7x04-4K_Eng_NP_V3.218.0000002.4.R.180704
General_HCVR7x08-4K_Eng_NP_V3.218.0000002.4.R.180704
General_HCVR8xxx_Eng_NP_V3.218.0000000.1.R.190618
General_XVR5x04_Eng_NP_V3.218.0000002.4.R.180704
General_XVR5x08_Eng_NP_V3.218.0000002.4.R.180704
General_XVR5x16_Eng_NP_V3.218.0000002.4.R.180704
General_XVR7x16_Eng_NP_V3.218.0000002.4.R.180704
4th Generation XVR:
General_XVR5x08-4KL_Eng_NP_V3.218.0000002.5.R.190301
General_XVR7x16-S2_Eng_NP_V3.218.0000002.5.R.190301
4th Generation H.265 XVR:
General_XVR5x04-X_MultiLang_NP_V4.000.0000002.11.R.190829
General_XVR5x08-X_MultiLang_NP_V4.000.0000002.11.R.190829
General_XVR5x16-X_MultiLang_NP_V4.000.0000002.11.R.190829
General_XVR7x16-X_MultiLang_NP_V4.000.0000002.11.R.190829
@EMPIRETECANDY
Software:
EVS:
NVR:
Older Lite:
Lite H.265:
Ultra IP Camera:
Fisheye:
SD/PTZ:
4th Generation XVR:
Got even bigger changes on the list now. If anyone has these, it would be appreciated. For reference, I have firmware stores here as well.
Software:
EVS:
NVR:
Older Lite:
Lite H.265:
Ultra IP Camera:
Fisheye:
SD/PTZ:
4th Generation XVR:
Reactions: Fenst
Should probably ask this in Andy's subforum, that's a massive list, haha
Software:
EVS:
NVR:
General_NVR4XXX-4KS2_MultiLang_V4.000.0000001.2.R.190929
General_NVR5XXX-4KS2_MultiLang_V4.000.0000001.0.R.20190930
Older Lite:
Lite H.265:
General_IPC-HX2X3X-Rhea_Eng_NP_Stream2_V2.800.0000010.0.R.190807
General_IPC-HEAT_MCU_V2.800.0000008.0.R.190619
Ultra IP Camera:
SD/PTZ:
General_SD-Chen-Nova_MultiLang_NP_Stream3_V2.640.0000000.6.R.181011
4th Generation XVR:
General_XVR5x04-X_MultiLang_NP_V4.000.0000002.9.R.190515
General_XVR5x08-X_MultiLang_NP_V4.000.0000002.9.R.190515
General_XVR5x16-X_MultiLang_NP_V4.000.0000002.9.R.190515
General_XVR7x16-X_MultiLang_NP_V4.000.0000002.9.R.190515
Want this one?
DH_SD-Eos_MultiLang_PN_Stream3_V2.800.0000000.5.R.190827 ?
I have the NP version of that one already in my OneDrive that I linked above. I'm good. I'm trying to get unbranded NP (NTSC primary) ones.
Witch Firmware do I need voor de IPC-HDBW4431F-AS?
My Dahua NVR sees this camera as a onvif camera instead of Private like my other Dahua camera
Can anyone tell me if my cameras should use this 10.0.R from 20190807 or this one DH_IPC-HX2X3X-Rhea_MultiLang_PN_Stream2_V2.800.0000008.0.R.190619.
I found the 10.0.R on the dahuawiki but I dont see it anywhere else. The 8.0.R is listed here.
I have HDW14312S cameras.
After much googling and browsing around Dahua's site, I found the official firmware support page: Firmware. I can't see it referenced anywhere else in this thread. It also seems to be updated continuously, contrary to the firmware page on dahuawiki.com where I couldn't find any of the cameras I purchased from Andy (1230S and 5241T-AS-PV).
It does mention "Europe" and "China" on the page, so maybe it's not supposed to be for US users. No idea. I guess all European and Chinese readers of this thread can possibly find working updates, at least I did.
Bonjour, Je viens de m'équiper avec 4 caméras DAHUA, suite à une mauvaise manip, j'ai fait un reset à 2 caméras.
Depuis j'en ai 2 en firm 2.800 000000 5.0R 2019-03-25 et j'en ai 2 en 2.800 000000 4.0.R 2019-01-22.Mes caméras sont des IPC-HFW2431T-ZS
.Je cherche la version à jour pour mes 2 caméras mais je ne trouve nulle part avec cette référence ... comme si cette ref n'existait pas ...pouvez vous m'aider ?merci
Is there a Dahua Firmware FAQ around? ie Best practice, recommended procedure, etc. IE download from x, validate x version matches your existing camera, reset to factory defaults after upgrading. Ideally an option to backup the existing version, etc. Also, what order to update the bin files?
