- Mar 9, 2014
- 36,891
- 21,418
why? you need to be using vpn, relying on dahua or any other camera manufacturer for security is just plain stupid.Will be bookmarking this thread to get a hold of latest firmware updates to address recent PSA by Dahua![]()
no firmware will get you IVS.. if your not having any issues; all you risk doing is breaking it
What date format is the firmware in? DD/MM/Year or MM/DD/Year?
Really? V2.460.0000.7.R.20170306.zip
Red = Year
Blue = Month
Orange = Day
There seems to be a new 2017 firmware release. My camera is a SD59225U-HNI PTZ
Did anyone try it yet?
Is it safe to install? And if so, which version should i use? In my country PAL is the standard, however the PTZ came with NTSC firmware installed. I prefer PAL. Can i run the PAL version of this newer firmware or will that brick my camera? Is there waranty from @EMPIRETECANDY if the firmware update bricks the camera?
I just installed it and it finally lets SmartPSS 2.0 have access to the setup configuration. I also had the PAL version and installed the NTSC version, no problems yet.
hi
i have 16ch analog dahua dvr,I used unmatch firmware and now the device is broke down.does any one have source firmware of flash ic?or something else? i have access to rs232 & i have got programmer & even i can program the flash ic.
the model lable is damaged so i send the motherboard picture.
in addition, i am professional technician in dvr repairing.
thanks.
[email protected]
+989358155541 whatsapp
Well, usually if you get this error you need to reset camera to default then try it again with browser or config tool .. i am sending you the full package of firmware again with flash files also if you know how to upgrade from serial port. i hope this work for you !!
Please download from DH_SD-Mao-Themis_Eng_P_Stream3_IVS_V2.600.0000.0.R.20170601.zip
