I updated one of my S3 cameras successfully, but I don't see any place to add "Animal" as an Effective Target. Do I need the latest fw update for my NVR as well in order for this to work?
Are you in the camera GUI?
I am but I don't see any way to set it up in the camera GUI either. I'll keep poking around.Are you in the camera GUI?
Interesting. I can't figure out how to do IVS through the Camera UI. I've always done it via NVR.It’s on IVS , apparently not SMD.
But I choose the AI by Camera setting, I just do it through the NVR interface.That’s bad.
You should do ALL settings on the camera GUI
go to AI, choose IVS - Follow prompts
IVS is much better than SMD. Do t try running both at the same time
I'm trying to figure out how to get that AI menu in my camera UI. perhaps it's because I have SMD enabled too? I had SMD enabled to catch things like animals, but now I won't need it because IVS can do it.On the newer NVR's which you have apparently, yes you can choose AI by Recorder (and lose 1/2 of your incoming bandwidth allocation) or by Camera on the NVR interface, but you still need to actually setup the IVS rules on the camera GUI if you choose by Camera
Animals not included in the new FW for SMD, only for IVS
OMG. A whole new world just opened up to me lol. Thank you.Click the house icon (home) top left of your camera gui you showed in pic about 5 posts up
Then choose AI
Then select IVS
Then the next screen is the IVS rule setup screen
I feel slightly better knowing I'm not the only one who wasted a lot of time over this poor UI design. AI should be on the Settings menu like most of the other home page settings are. It's worse for anybody who used the older camera UI, where IVS is under the Event menu, which to me is a whole lot more logical than where it is now.I'm trying to figure out how to get that AI menu in my camera UI.
No kidding. I searched and searched but had no idea that icon meant so much.I feel slightly better knowing I'm not the only one who wasted a lot of time over this poor UI design. AI should be on the Settings menu like most of the other home page settings are. It's worse for anybody who used the older camera UI, where IVS is under the Event menu, which to me is a whole lot more logical than where it is now.
@EMPIRETECANDY What's the latest firmware for IPC-T5442T-ZE? I have a camera with version "V2.840.0000000.25.R, Build Date: 2023-04-25" that does not have "Smart IR", and another one with "V2.840.15OG00D.0.R, Build Date: 2022-08-18" that does have "Smart IR". Is there a newer build that has Smart IR?
empiretech01.com
