Ok good to know, learning and learning.If the cameras are plugged into the POE ports of the NVR, they are assigned 10.1.1.x IP addresses.
This is intentional and by design and the NVR acts as a firewall/router of sorts to keep the cameras off the internet.
Thanks alot.Are the cameras plugged directly into the back of the NVR?
If so, ALL cameras plugged into the NVR will have IP's of 10.1.1.X beggining with .65 for port #1
The NVR has its own built in switch. Dont mess with the camera IPs, the NVR assigns them based on what port you plug them into
Dont mess with Gateways on cameras, they adopt the NVR by default. . 192.168.3.NVRIP would be the best gateway
So you will need to default that camera. Open the door on it and press the little black button for 30 seconds while connected on port #1
ALways plug the camera into the same port, dont switch them around
Thanks alot to you guys.Thanks alot.
Could that also be a reason why the stream was stuttering because the camera gateway was set to 192.168.1.1 but the NVR is at 192.168.3.x
yes its on an iphoneIs that DMSS on a phone, iPad? Doesnt look like DMSS
Never seen that, can't help ya there
Hello, sorry for asking again question.Is that DMSS on a phone, iPad? Doesnt look like DMSS
