Only if I have any left to leak.......So Tony Your gonna be leaking Brown and Yellow then?
Didn't seem to bother the spiders.Yikes!
In the U.S. of A., Brown-Orange-Yellow is 480 VAC, 3 phase (277 VAC to neutral)....it is NOT as forgiving as 120/240 if you get across it!
I suspect that is a local motor disconnect on some type of conveyor.....in a really dirty environment.Yikes!
Well, at least they used lock washers...
Mmm, I bet that vehicle was fun to ride in.....until they found their first pothole.......
That should work for a little while! Since these custom brake pads are on the rear brakes they won't get quite as hot as the front brakes do! lol
				Since this seems to be the mechanical joke thread. Some of you guys might get a kick out of this one…
