DS-2XS2T47G1-LDH/4G/C18S40(4MM) - Initial Set up problems
Nov 23, 2025
2
3
USA
Seeing if I can get any ideas or pointers. I'm trying to demo the DS-2XS2T47G1-LDH/4G/C18S40(4MM) hikvision camera. I've got the debug LAN to ethernet connector, and supplimental power. I have it directly connected to a PC. I have set the IP manually for the PC, and with a continous ping the thing is, the camera boots, and eventually blue blinking lights, and IP is alive at 192.168.1.64. SADP can see it, I can browse the the camera's IP and looks like I can set it up. However, then the light turns red, and the IP not longer responds after about ~5 seconds. Then every ~10 minutes or so the IP responds again, but only for 2-3 pings, then no response. If I hold down the reset button to tempt it into blinking blue pairing mode, no reliable reaction. A reboot will get the IP to respond again, but only briefly, then back to solid red light. Eventually the unit will reboot in what looks like a boot loop, and ends up with a red light basicly.
Same behavior with and without a SIM card in it. Firmware is latest: Firmware__V5.7.20_250924_S3000680058
Any pointers or ideas? Odd behavior.
