fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,417
Reset the cameraThe packaging says the ip is 192.0.0.64
Thanks !
Thanks !
Reset the camera
OK, if we assume the packaging is correct, try this:
Just leave your router at its normal settings.
Change the IP address of your PC to 192.0.0.128, subnet mask 255.255.255.0
Gateway does not matter, but if the PC complains, use 192.0.0.1
Confirm the PC is wired to the router.
Confirm the camera is wired to the router.
At a command prompt on the PC, use 'ping -t 192.0.0.64' to set a continuous ping going.
Power on the camera.
Check for any ping responses.
If you get continuous responses, the camera is confirmed as using the IP address 192.0.0.64. Start your browser, go to URL 'http://192.0.0.64' and hopefully you will get a login screen, and should be able to use 'admin 12345' for 'Username password'.
If the camera does show a few ping responses that stop after a few seconds, and do no recur of their own accord after some 10s of seconds, the camera is either set to use DHCP or a different static IP address.
Assuming your router DHCP is working OK, we would expect SADP to find the camera for either case.
Good luck!
Is it a new router?
is it built in to your ISP modem?
