SpacemanSpiff
How long before manufacturers include a GPS receiver in their cameras?
Mental note to self: start product design on faraday cages for security cameras for blocking new built-in GPS 'phone home' feature
I have dahua brand cameras, and I am not cool wtih the smartpss app requiring admin access to run on my PC. I don't think it should need this for normal operation and I fear that it is part of a manufacturer backdoor to my PC. I can and do isolate my cameras and NVR, but I want to keep internet access on my main PC where I monitor cams. Does anyone have a convenient solution for this, or know of 3rd party software to monitor multiple cameras? I want to be able to monitor up to 6 4K cameras with scaled view of primary or sub streams on my second display and click them to see full res, the ability to zoom, the ability to turn on audio, and the ability to playback from the NVR - essentially smart pss minus the admin to run requirement. Even better if I dont have to install it all. Something like a portable app that can store its config and that runs without admin maybe?
Many here use Blue Iris. I have a Dahua NVR but will be moving to Blue Iris or Frigate (or another Linux-based VMS) later this year.
It's easy to isolate the cams from the internet and will have the server PC hooked up to the internet by using two network cards. Very inexpensive and easy to set up.
All true, but I would like to be able to watch them from afar. And now risk kicks in.
Log into the NVR's builtin web page with a browser.I have dahua brand cameras, and I am not cool wtih the smartpss app requiring admin access to run on my PC. I don't think it should need this for normal operation and I fear that it is part of a manufacturer backdoor to my PC. I can and do isolate my cameras and NVR, but I want to keep internet access on my main PC where I monitor cams. Does anyone have a convenient solution for this, or know of 3rd party software to monitor multiple cameras? I want to be able to monitor up to 6 4K cameras with scaled view of primary or sub streams on my second display and click them to see full res, the ability to zoom, the ability to turn on audio, and the ability to playback from the NVR - essentially smart pss minus the admin to run requirement. Even better if I dont have to install it all. Something like a portable app that can store its config and that runs without admin maybe?
In that case, let me try this to see what happens:
Eva Vargara nudes
I have tried blue iris, that was no good. The biggest problem was the CPU consumption, and the resulting power hog that turned my PC in to. If it supported Dahuas API to offload motion detection to the cam since its a low power arm cpu that already implements the detection and provides an API that would be ideal. Then the PC wouldnt need to decompress the streams to implement anything, it could just save the compressed stream, like an NVR. I also was not a fan of the BVR format and the lack of a stand alone tool to convert to MP4 in a lossless way. I found scripts that said they did it with ffmpeg, but it did not work for me. I also found I could set up an auto export but that was a pain and involved re-encoding the streams. Not what I was looking for.
