sebastiantombs
The van is rehearsing for a part in the next "Predator" movie without a doubt.
If you are using the substream change the encode mode to h.264 as well.Ah, so there it is.....
Smart codec. I have now turned this off.
Good catch. Just changed that, also. Funny when I set all of that up using Amcrest IP Cam config, it didn't take, I guess. I no longer use that app anyway.If you are using the substream change the encode mode to h.264 as well.
