disable desktop frames possible?
rotation
Joined
Mar 26, 2018
Messages
84
Reaction score
9
When dragging a camera window out of BI the window becomes a separate window outside of BI and potentially hidden behind all other windows.
Is there a way to disable this behavior?
My dad dragged out a camera making it a separate window and trying to fix it made it worse.
It would be sufficient to disable this desktop frames.
TonyR
Joined
Jul 15, 2014
Messages
17,477
Reaction score
40,704
Location
Alabama
Just right-click on the newly created desktop frame and then select (left-click) on "open in desktop frame", removing the check mark....it should go right back to where it was before the desktop frame was created......easy peasy lemon squeezy! :cool:
rotation
Joined
Mar 26, 2018
Messages
84
Reaction score
9
yes, but the frame was in the background. I was rather asking if it is possible to disable this function entirely
TonyR
Joined
Jul 15, 2014
Messages
17,477
Reaction score
40,704
Location
Alabama
This may help. Your dad may be still left-clicking (holding left button down) on a camera window when he pulls away from it, causing the desktop frame. If so, try this:
  • Right-click on a black portion of the screen.
  • Click on "Drag lock" to put a check mark by it (enabling it).
This way he's less likely to accidentally create the desktop frame.:cool:
bp2008
Staff member
Joined
Mar 10, 2014
Messages
12,659
Reaction score
14,100
Location
USA
It is worth mentioning that newer versions of Blue Iris don't allow dragging cameras from the main view anymore, so I think the drag lock function is only found in older BI versions.
In the current Blue Iris, you must click a button 1713811635441.png to enter "Edit layout" mode in order to drag cameras.
Top
