Direct burial cable recommendation
105437
BIT Beta Team
Jun 8, 2015
2,271
1,112
It’s been almost 8 years since we built our house. At that time, I ran several Cat5e runs to outdoor cameras using direct burial cable.
Just recently I’ve had issues with one camera that’s ~270 feet from the PoE switch in the garage. Cable tester shows there’s a short somewhere.
Rather than trying to find where the shirt is and patch it, I’m going to replace the run. Looking for some good quality direct burial cable and would appreciate some recommendations. Thanks
any DD cable is fine monoprice or unifi.. We're using commscope. cat6 on the pricey side.
Reactions: mat200 and 105437
As an alternative , if the short is in the orange or green pair, you could swap the bad pair with brown or blue. Adding for due diligence, the camera has to be unplugged when using the cable tester.
@105437 The problem with direct-burying Ethernet cable is that critters (moles, mice, etc.) will find it and eventually chew into it. This is likely what has caused the short. It's much better to bury it in conduit. And I echo the sentiments of the others—Cat 5e is fine, use solid copper, and with the length of this run using PoE, be sure to use 23awg instead of 24 to minimize voltage drop. That said, gel filled will help keep water out, and the taste might discourage critters from chewing past the main sheath into the wires.
Thanks for the replies everyone. I've ordered a better tester that will tell me which pairs are shorted. It can estimate where the short is. I'm sure that's probably not very accurate. If I can find the damage, I'll patch it temporarily while I run new conduit the length of the run.
Reactions: tigerwillow1
Searching for different options to use as conduit. Is gray PVC pipe conduit the most economical one to use?
That's what I've used .. worked well enough so far for me
