Hi, thank you for your answer.
Already search "IPC-HDBW4631R-ZS" on www.dahuasecurity.com and did't find anything.
Learn more here, and better buy original english models.Ok, now I have a chinese language camera :-(
This new firmware does not require a plugin. Your worries are over.ok do i have any kind of worry with different versions of the plugin? last time i tried updating one of the cameras i ran into a problem where the nvr and ip cams were (I think) trying to use different versions of the plugin and I ended up reverting everything. *edit to clarify i have a dahua nvr, that i believe has gotten it's last firmware, so worried if i installed the new plugin for the new camera firmware i won't be able to get into the old nvr (last time i had to purge the plugins, and revert everything back to older firmwares)
use chromeOk I installed the firmware but when opening it in ie is telling me to install a plug-in when going to that camera. I'll link the one installed to confirm I installed the right one, when I get home.
yes and icognito mode, also firefox which i never use.Did you clear your browser's cache
I get same playback tab issue with edge, live works fine with edge/chrome/firefox for me. edit* Looks like the previous recordings are showing, but playback will not show the timeline view so i can actually view anything, as well as only lets me download in dav, not mp4 anymore.Chrome gives me a spinning circle where there should be video, but Microsoft Edge works for me (no plugin needed).
Oh my god, where i mention this firmware can work for IPC-HFW1320S-W?After the update my IPC-HDW4431EM-ASE to "V2.800.0000005.0.R, Build Date: 2019-03-25" shows the video even in Firefox 67.0.4-64
but another Dahua camera IPC-HFW1320S-W ("2.400.0000000.16.R, Build Date: 2017-08-31") doesn't show video anymore and says "Please click here to download and install the plug-in" (I suppose it's because of "wrong" plugin version...)
Is there a way to install 2 different versions of this plug-in?
Or where can I find "the same version Firmware" (Build Date: 2019-03-25) for Dahua IPC-HFW1320S-W ?
Or any other ideas?
Hmm...Oh my god, where i mention this firmware can work for IPC-HFW1320S-W?
But I like Your idea!this firmware can work for IPC-HFW1320S-W
