DH-SDT4E425-8P-GB-APV1 Problems with auto tracking
Aug 11, 2025
2
Netherlands
Hi all,
this would be my first post here .
I have several mainly Dahua cams in my system and lately i installed at a friend of mine and here on my parkingspot the same camera (DH-SDT4E425-8P-GB-APV1)
The image is pretty good, also the auto tracking works decent untill this happens.
The older model EOL cam i have has i think autotracking v2 and this should be V3 but that cam works flawlessly this one not so much.
Some camera info:
Device Model
ONVIF Version
23.12(V3.1.0.1734191)
System Version
V3.200.0000019.1.R, Build Date: 2024-12-19
Web Version
V5.01.0.2160692
PTZ Version
V2.401.0000001.84.RHNGC_240105_49361
Algorithm Version
1.0.3
Security Baseline Version
V2.4
H5Player Version
V3.01.1
What i have done is setup the camera,
  • set a preset
  • then go to AI
  • from there SMART PLAN and made a rule
  • i used Tripwire and selected a box
  • did not put a minimum size in , and maximum size is the whole screen.
  • turn on direction both
  • turn on human filter and vehicle
  • turn on action appear and cross
Step 2
Went to Panoramic linkage and selected
  • enable
  • auto tracking
  • follow until xx
  • size
What happens is when for example a car drives into the tripwire border, it follows, and person gets out walks away, its in a sort of loop and it does not stop until i press the zoom or a preset in PTZ then it returns after X minute and works like should again.
( i have seen this behaviour also on the wall at my friends cam, here you can see a little video where it is focussed somewhere on a wall after it tracked a car and stays in the loop)
Made a recording of my screen where it does this and it doesn't stop from itself.
Does anyone know or has the same experience with this ?
Hereare the screenshots of my settings:
next:
And here is the video:
( I might have a "solution" that is set a max time for tracking instead of the options :
  • Continue till object dissapears
  • Track untill objets tracked by detail camera dissapear
But at the - Custom option you can set the time and it should aways go back to the desired preset location but still this should not behave like this does it ?)
