DH-SD6C3425GB-HNR-A-PV1 bootloop and firmware flash
Virgin
May 5, 2026
1
Katė
Helloo warriors. I have a problem with SD6C3425GB-HNR-A-PV1 PTZ camera. It was working for like one year and somehow it stopped working after the night. There was no electric shock, I wasn't updating firmware, weather condition was normal. It seems to be stuck in bootloop. It appears in config tool for a few seconds and dissappears, I can't log in using web interface, I can't initialize camera from config tool. CMD Ping works, but after about 4 minutes ping dissappears for like 10 seconds and comes back. I can hear camera "tick" every ~4 minutes, it seems to be rebooting. I tried to rewrite firmware using TFTP method with lan cable, it seems to be successful, but situation doesn't change, except I can see in config tool for one second that firmware changed. I was following this thread . My commands were:
tftp CONFIG_SYS_DEFAULT_LOAD_ADDR dhdtb.bin.img; flwrite.
tftp CONFIG_SYS_DEFAULT_LOAD_ADDR dhboot-min.bin.img; flwrite.
tftp CONFIG_SYS_DEFAULT_LOAD_ADDR dhboot.bin.img; flwrite.
tftp CONFIG_SYS_DEFAULT_LOAD_ADDR pd-x.squashfs.img; flwrite.
tftp CONFIG_SYS_DEFAULT_LOAD_ADDR romfs-x.squashfs.img; flwrite.
tftp CONFIG_SYS_DEFAULT_LOAD_ADDR kernel.img; flwrite.
tftp CONFIG_SYS_DEFAULT_LOAD_ADDR firmware-x.ext4_aa.img; flwrite.
tftp CONFIG_SYS_DEFAULT_LOAD_ADDR firmware-x.ext4_ab.img; flwrite.
tftp CONFIG_SYS_DEFAULT_LOAD_ADDR firmware-x.ext4_ac.img; flwrite.
tftp CONFIG_SYS_DEFAULT_LOAD_ADDR web-x.squashfs.img; flwrite.
tftp CONFIG_SYS_DEFAULT_LOAD_ADDR .FLASHING_DONE_STOP_TFTP_NOW.
sleep 5
Every file seems to go successfully.
I have uart ttl adapter too and tried tftp install using uart, also sd card upgrade, every file seems to go well, I tried fw from dahua web Dahua Technology - World-leading Video-centric AIoT Solution and Service Provide
My printenv, help and partition info attached:
Uart log if I don't stop booting:
DH-Boot ver001.001.001-svn10032 (Mar 29 2022 - 00:10:56 +0800)
MMC: host init
dhboot flash register.
$Tch SpiNand
Tch SpiNor
Tch Mmc
Image flag error! read=0x00000000
DScan SpiNand
scan blk : 64
scan blk : 128
scan blk : 192
scan blk : 256
scan blk : 320
scan blk : 384
scan blk : 448
scan blk : 512
scan blk : 576
scan blk : 640
scan blk : 704
scan blk : 768
scan blk : 832
scan blk : 896
scan blk : 960
scan blk : 1024
DScan fail!
DScan SpiNor
Image flag error! read=0xFFFFFFFF
DScan fail!
DScan Mmc
Load 0x00000080 to 0x00100000,size=31004
imgcrc pass!
Jmp 0x00100000
Info: write leveling start
Info: write leveling done
Info: dqs gating start
Info: dqs gating done
Info: read train start
Info: bypass read train done
Info: write train start
ddr init done
simple ddr test
swap
ddr_clk: 599500
cpu_clk: 1000000
enc_clk: 400000
DDR32bit done!
B: Mar 29 2022 00:11:21
chip id is 0x0x7FB3804C
mac io keep 3.3v
PreImgHeaderBase = 0x0010FE78
Mmc : Scan Uimg @0x50200000
use 2 plane to read
Load 0x50200040 to 0x12000000,size=197584
Jmp 0x12000000
Looking for any advice what could I be doing wrong.
