DH-SD22204UE-GN - tuning tips for day and night
Image is improving at night... if I were to upgrade this nice sized PTZ with another similar what would you all recommend?
Current requirements
  • Outdoor PTZ
  • IR built in to improve night vision
  • Audio (nice to have)
Show us an image at night to compare
Budget?
B&W or color?
Distance needed?
Auto Tracking?
They work best higher up. You have a place 15+ ft in mind?
I ask because you are looking at a range of $250 to over $2500 and they aren't the same ;)
Reactions: looney2ns
  • Budget? ~$500
  • B&W or color? Day - Color, Night B&W is fine
  • Distance needed? 45-65ft
  • Auto Tracking? Not sure why I would need auto tracking... just watching backyard and nighttime wildlife (bobcats, bears, mountain lions, etc)
  • Height - 10ft high
  • Profile - Low profile
Andy has a number of cheap ones. I;m not familiar with any of those
Then there is the Mini which a lot of us have and like
Autotracking means the PTZ can by itself, recognize and track targets, human/vehicle/animal (some)
Problem with most of them:
a- 1/2.8" sensor on 4MP (4K would be even worse) is not a good match especially at night
b- some like the mini flat suck at night due to weak IR
Because most use that lesser sensor on 4MP the #1 thing to look for IMHO is strong IR and/or white lights to help it see at night
Remember to cut the spec IR distance in 1/2 to start
Personally I'd look at these 2
Dont know what Andy wants for this new one - much stronger illumination
Maybe someone else has a current recommendation, Dahua has a bunch of new smaller PTZs out
Reactions: tomas21
Keep in mind most any ptz will start at 60 degrees or less at minimum zoom so depending on where you keep yours parked now you may end up with a much narrower field of view. The main exception I know of from EmpireTech being the PTZ3E405-AI with 95-30 FOV, there’s a few others including what you have now but they’re not going to be any better. I installed one in my barn and it does fairly well but it’s definitely at the low end of PTZ’s and 4mp on the not ideal sensor. I’d recommend a fixed lens at 2.8 or 3.6mm backed up by a ptz. You may be surprised just how much you can see with a 4mp camera on the proper 1/1.8 sensor.
Thanks ... the newer version of the PTZ425DB-AT.............. the PTZ425DB-AT-R looks good.
Its the same camera with a smoke cover.
Its a great little PTZ, for daytime, weak IR at night
I thought I heard the -R has a quieter ptz motor?
That could be? I'm not aware.
I do know the mini can be loud. Many of us call it R2D2 (if you're under 55 you may need to look that up)
Per Andy at Empire...
-R model with smoke glass, invisible lens, so hard to see where the camera is watching at. But less IR distance, But very quiet. Best for indoor or some place that don't want people know there is a camera here.
PTZ425DB-AT This one a little noisy, but stronger IR, so can reach far at night.
AI function they are the same.
Same camera except for the smoked lens which reduces IR range I believe. Its Not noisy such that your neighbors or you will hear it over the television
But yeah on a quiet morning a close by walker may hear it and look up. Which is a good thing, face ID for free!
Picked up the PTZ425DB-AT but big oversight on my part... the horizontal FOV is reduced by half and now i can't capture as much as I could before with the former DH-SD222O4UE
Feature
DH-SD22204UEPTZ425DB-AT (Dahua/EmpireTech SD4A425DB-HNY)
Focal Length2.7 mm–11 mm5 mm–125 mm
Wide Angle of View (Horizontal)112.5°51.9°
Optical Zoom4x25x
@97JeepXJ Thanks for the tip... I think I'll swap out my SD42212T-HN with the newer PTZ425DB-AT and re-evaluate what is the best PTZ to replace the DH-SD22204UE
Reactions: 97JeepXJ
Kinda new. Havent played with one, but as long as you have some good external ambient light and run the onboard lights, it should be ok
personally I'll never buy another 4MP camera with undersized 1/2.8 sensors
That is what I'm afraid of... i'm looking to replace my current solution DH-SD22204UE-GN 2MP 1/2.8” CMOS -- FOV H: 112.5° ~ 30° / 2.7mm~11mm
The two current solutions fall into that situation since I'm trying to find a PTZ that has wider FOV given its in backyard monitoring pool area and like to ptz to check sides, hill behind us, etc and something lower profile if possible : )
  • PTZ3E405-AI - 4MP 1/2.8" CMOS --- wider FOV H: 94.9°–30.1°; (2.7 mm–13.5 mm)
  • PTZ3E10X-T180 - 4MP 1/2.8" CMOS + 8MP --- wider FOV H: 180° (2.8 mm) --- believe this will take two channels on the NVR
To be fair, it really does come down to how much ambient, coupled with inboard, light can be brought to bear. (And required distance)
What’s your scene like?
Sorry just saw backyard/pool.
So yeah with the onboard lights and some external motion floods I would think it would work fine
For night viewing all things equal with tracking animals (bobcat, bears, etc) which camera would be preferred between PTZ3E405-AI & PTZ3E10X-T180 ?
Distance is 10-65ft
The 3E405 would probably suffice, but only 13.mm zoom which is same as most varifocal cameras. The other is 40mm, far more powerful zoom
BUT- neither has Animal filter for tracking
Most PTZs don’t track critters, well not on purpose
Reactions: tomas21
