Are you using facial recognition and / or the custom "Dark" model?
No facial recognition but I am using the Dark model.
Shut off auto update in BI. You'll still get notifications in the log and control console window, but you can pick if and when to install updates.
It's fun to be on the "bleeding edge" but I've found that sometimes an auto update can happen at the worst possible moment and crash the system when I don't have time to fool around. That raises the blood pressure and stomach acid significantly. Plus, by waiting, I get to let other folks be the initial test installs before I take the plunge.
Turned off facial recognition at 1:43 PM, so I will check later today if I am still getting DeepStack server errors. Coincidentally, after turning off facial recognition, I restarted BI and OF COURSE it picked up Ken's brand new 5.4.8.1 update. That seemed for fix the issue with closing out the clips issue mentioned above.
So even after turning off facial recognition, I am still getting the "DeerStack: Server error 100" and "DeepStack has been restarted" error in the log. I guess I will remove the "dark.pt" file from the custom models folder / restart BI and see what happens now.
