The new model I trained using a different base model, the old was trained using yolov5m the new model I used yolov5s.What allows for these improvements?
Thank you for the screen shots.You need to create a folder in the DeepStack folder (MyModels) and copy the license-plate.pt file there. Also check the box next to Use custom model folder. Below are my camera IA settings.
Thank you I see it now.
Try changing the folder name back to Blue Iris default name (C:/Deepstack/MyModels) and make sure settings match.Cant seem to get custom models working. If I have any files in the custom models folder in Deepstack for example
C:/Deepstack/CustomModels/licence.pt
Will cause my Deepstack to time out and not detect anything
C:/Deepstack/CustomModels/Licence/licence.pt
Works but I dont think its actually scanning any custom models or for this matter licence plates.
Any idea why Deepstack would just timeout and not scan with a .pt in the custom folder directory.
Below are the settings I use.Seems to be missing heaps of vehicles. Is there a way to combine your License-Plates with this GitHub - odd86/deepstack_licenceplate_model: Deepstack Licence Plate Model.
What should I be putting in the custom field to enable all Custom Models? is ";" still applicable and would I need to modify the "to confirm" and "Mark as vehicle"View attachment 112385View attachment 112386
Missing a few cars that are bright and clear as day. Would modifying "analyze one each" and increasing to 250-500ms fix this?Below are the settings I use.
n
@OfficerD00fy below are my Trigger and AI settings for Day and NightMissing a few cars that are bright and clear as day. Would modifying "analyze one each" and increasing to 250-500ms fix this?
Cars approximately 30-40km/h will get picked up.
Anything 10-20km/h (Snail pace) doesn't get picked up as a licence plate.
Would you be able to post your pre-trigger recording and hot spot settings. I think you've perfected your setup... mine not so much.
I have your license-plate.pt working with the licence-plate.pt so hopefully better detections.
@OfficerD00fy did you get the custom model working with the settings I posted?Missing a few cars that are bright and clear as day. Would modifying "analyze one each" and increasing to 250-500ms fix this?
Turn on Save DeepStack analysis details and post screenshots of the canceled alerts DeepStack analysis details
Do you have a day and night schedule set for just the LPR camera green is day red is night and do you have all of the trigger setting as the previous postI can't even run the DAT file in time. The Alert lasts one second.. Day works well.
I've forgotten what settings I had for night where it'd be at least picking up 60% of the vehicles. As soon as night comes it gets 0 plates now.
Actually I think Deepstack is not even analysing at night. It just says Motion A. Usually it says nothing found. I assume maybe a setting is wrong?
