I've gone for the Z12 because the current camera is pulling images from 30m away so I wanted something that could match itI have the Z5 and it's working great for me. I may get the Z12 just to play with it and see what's the difference. I think the Z5 may have a wider FOV than the Z12 but in my street, the Z5 is working good and FOV is good for both incoming/outgoing traffic. Z12 has a better zoom but I'm unsure whether the FOV would work in my favor.
Thank you, I have the stream URL. Verified it's correct via VLC.openalpr is pretty easy, just grab the stream URL and put it into the configuration. It'll start streaming it.
Just install openalpr-latest.exe on Windows. Once you do that, it creates a WIndows service. Open the app and sign in with your account. On OpenALPR website, you configure the agent that you just installed and specify your camera stream by adding a camera.Thank you, I have the stream URL. Verified it's correct via VLC.
Do I have to be running ALPRD?
I was looking at just alpr.exe in the windows binaries and passing that the stream URL, but it doesn't appear to accept a stream URL, just images on a manual CLI basis.
I am probably missing something obvious to those who have done it before, which is why I ask Sorry I'm not trying to be dumb. I have spent some time looking thru the files, found a conf file in the root of the ALPR directory but it didn't have placeholders for a stream URL to edit.
I appreciate your time.
Remote Access/RTSP via VLC - Dahua WikiTrying to get OpenALPR running. One issue I am having is how go determine the URL stream. I have no clue how to get the URL stream information. The camera works fine by typing the address into a browser. Can someone help? Thanks.
Funny how the specs always listed 1080P for the second sub-stream, and finally it actually worksJust upgraded the firmware in my plate cameras. The latest DH_IPC-HX5X3X-Rhea_Eng_P_Stream3_V2.460.0000000.16.R.20170904 firmware makes the second sub stream 1080P, up from 720P. I've been feeding the 720P substream to openalpr with mixed results. Rear plates generally read but the smaller front plates often don't. I'm hoping that the bump to 1080P might help that.
