tangent
			- May 12, 2016
- 4,641
- 3,997
The main ALPR software discussed in this thread is OpenALPR which is available for free.when you will release the lpr software? I will donate money for your time.
Start with a pre-compiled build for windows: Releases · openalpr/openalpr · GitHub@nayr Would you have time to write up a "how to" for ANLPR? I looked at your code up on get hub and I compared the conf files to the ANLPR I downloaded for my windows box but it's not syncing in how you have it running.
Reposted here my answer to a private message about my use of a long SLR lens, in case it is useful to others.
For extended range (plates at 200+ feet) I am using a fully manual old-style Nikon SLR lens, no auto iris, no auto-focus and that is what I recommend. Also needs F-mount to C-mount adaptor. For example NIKON NIKKOR-H 50MM F2.0 LENS (NON AI NIPPON KOGAKU) | eBay plus Camera Adapter For Nikon F Mount Lens To 16mm C Mount Film Movie Adapter | eBay
There is no way to activate a focus motor in a SLR lens without the SLR camera body, even if it was an autofocus model. Fortunately, you don't have to! That's the good news. The Dahua IPC-HF5421E camera I have has its own focusing motor that instead moves its image sensor back and forth by remote command (script), so you can remotely adjust focus the camera even with a fixed manual lens that never moves. I've never tried to do this from Windows, I only use Linux for this stuff. I do not attempt autofocus, I just have my script switch at sunrise & sunset between two fixed settings found by trial & error (one for day, another for night with 850nm IR illuminator).
Yes, for less money you can get one of those 6-60 mm CS mount lenses. I did myself, and I also tried one of the few available 100mm CS lenses, before I ended up with an SLR lens. They do work but mine had glare / flare on bright spots, not really sharp/crisp. Maybe I'm a perfectionist but I was never happy with it. If you care about image quality the Nikon SLR lens is *much* better, although it is big and heavy and never designed to mount on an IP camera the way I did. I wonder a little about the mechanical stress on the lens mount, but my 100mm lens + long hood has been OK so far.
This is the same camera that I put a photo from here:
ALPR: anyone have a 100mm lens they like?
Here are some photos of my current setup, the Nikon SLR lens on the Dahua box cam using F-mount to C-mount adaptor. In background of one photo is a homebrew IR spotlight. After installing I put "black wrap" foil around the lens hood and camera body, to keep some dust off and make the white camera body stand out less.
	Spent my Sunday setting up my 2x IPC-HFW5431E-Z5 as dedicated LPR cams.
Is that only using the inbuilt IR from your two cameras, or do you have additional IR?
