DB DBCompact: could not obtain exclusive DB access 0/45600 0/45600 0/0/0
mvoss
Pulling my weight
Oct 21, 2023
128
101
Texas
I get this error whenever I schedule or try to Compact the database. The only way I am able to get the database to compact is to shut down the service, restart the service, and run the compact immediately.
I have the schedule to only run once per week. Any ideas on how to fix this?
I have evern deleted and had BI regenerate the database but that did not fix it.
Thanks,
Michael
What version please, not sure if it relevant or not?
Also have you excluded your BI folders from scanning by you Antivirus software
Can you do the rebuild manually from within BI, is the rebuild scheduled from within BI?
Hi Bruce,
I'm on 6.104 but this has been happening with other versions also. I could be wrong ut I noticed it not long after I upgraded to 6.0
All my folders, inclusing thw BI process is excluded. I have defender turned off so it never runs.
The rebuild is scheduled w/in BI. I'll try a manual rebuild and see what happens.
Thank you for the reply.
Michael
