Dahua WizColor 5x59-PRO and SmartLight 5x59-IL new series
I would think that like my 3449PRO you should be able to control the warning lights by either A) drawing another duplicate tripwire and making one activate and one not using a separate schedule for each, or B) setting an interim block of time (extra profile) where you want different light behavior.
I use a Custom 3rd profile beyond Night and Day to allow for the lights to not be enabled in the evening when we use that area as a smoking lounge for example
(No I havent reset the monthly estimated sunrise/sunset times on that cameras as I was using it to test to sort out a plugin issue)
Thanks for the tips ! Funny, but when I first logged into camera, everything worked fine in Edge with NO plugin installed. It was asking for it but I just clicked close. I did try to install the plugin and then I got the dreaded white screen for the video part. I had to go into the plugin folder and run the uninstall to remove it. Then Edge would work fine again.
Jmcu has already done a review and comparisons, I might throw a video up some time , but I am not good at reviews.
Those two outside photos were from his phone I believe
Reactions: EMPIRETECANDY
Don't use dahua official fw if you are a newbie, their fw is not good.
i recommend to use our own fw, i have a latest 20250928, i will post on our website tomorrow.
i recommend to use our own fw, i have a latest 20250927, i will post on our website tomorrow.
Thanks! Will use yours, first night running the T54PRO-ZE outside. Long day running the Ethernet, testing, tweaking. with further adjusting placement tomorrow.
Thanks! Will use yours, first night running the T54PRO-ZE.
Yes the camera it comes with 0731 works good, but not the best, the 0827 Auto is bit poor, so we make tons of work on it to make them good, and find a balance. For high tech skill guys can work well with the manual settings.
0927 i post a temporary link here, guys can download it. I will put on website tomorrow.
Reactions: alekk
Great, what about the algorithm file.
  • Love
The PFB203 works fine with the new cam. All you will need to do is drill three new holes, as I did in the attached photo.
Cool, thanks for sharing, so will be easy for guys who use the old PFB203W and no need to change it.
Later all wall mount on turret will be the PFB2203W.
GREAT timing @EMPIRETECANDY as my camera is scheduled to be delivered tomorrow afternoon - getting excited! ;-)
