Can I access somehow SD Card remotely (without removing/opening device)?Not sure. It's POE, and im not sure if something like that exists? power is fed through the RJ45 port, through 803.11 spec.
Thank You
It does make that voice 'calling now' and/or 'call was not answered' if you dont pick up - but they can be disabled in the options.
Mine is hardware disabled right now due to the zwave sensor I have added - the resistor I added doesnt allow the voice to be triggered which I like better.
Please, does anybody know the solution, where in the options to turn off the "calling now..." speech...and my second question is, how to make it happen, that I can see and hear if somebody is ringing at the front door on my app, when I'm not home (over the internet), it is connected over PoE with own local IP.
I have Dahua cameras and NVR installed and everything is working fine with the apps.
Thank you for your reply. The VTO is facing a road with some traffic...I managed to see the picture and to unlock through the app (it needs a scan of the SN and to connect it in the P2P option in the app, not the IP as the cameras). But still...how can I make it ringing on my phone, if someone press the button and I'm not at home? This option was actually the reason, why I bought the Dahua VTO.
hello
I do have in my LAN and in the Internet (when I choose Live Preview) a live picture and I can open the lock and talk...it is just not ringing in the app, I can't find the option to enable push notification in my mobile device (OnePlus3).
ok...It works now in my home network and in the internet... I opened ports and voila...
Thank you, for being patient with me as noob![]()
Did you do port forwarding or port trigger?
Hi all, can anyone advise if you install an SD card to the camera, it will take a photo each time the button is pressed?
If in the event some one presses the door bell and I happen to miss the alert on my phone, I'd like to know who was actually there. Would be great if this can be viewed remotely?
The other option I could connect the LAN cable to my hikvision ds7608ni-i2/8p and hope I can get it to communicate by that and set the motion detection alerts.
Thanks
will the VTH1550CH work as a inside door bell/chime, rather than the hack? Video Intercom/Products/DHI VTH1550CH - Dahua Wiki
I will be connecting vto2111D via POE to the existing dahua NVR with 4 dahua IP camera system
Thanks catcamstar. Is it possible to plug the vto2111D directly into NVR4108-8P-4KS2
nvr and still have it work like a doorbell with iDMSS app and the VTH? Or do I need a Poe injector/switch to LAN?
