ffmpeg
ffmpeg -f lavfi -i anullsrc -rtsp_transport tcp -i 'rtsp://username:[email protected]:554/cam/realmonitor?channel=12&subtype=2' \
-tune zerolatency -vcodec libx264 -pix_fmt + -c:v copy -c:a aac -strict experimental -f flv rtmp://a.rtmp.youtube.com/live2/xxxx-xxxx-xxxx-xxxx
@bug99, thats a glare reflection from the car's reflectors..
Code:ffmpeg -f lavfi -i anullsrc -rtsp_transport tcp -i 'rtsp://username:[email protected]:554/cam/realmonitor?channel=12&subtype=2' \ -tune zerolatency -vcodec libx264 -pix_fmt + -c:v copy -c:a aac -strict experimental -f flv rtmp://a.rtmp.youtube.com/live2/xxxx-xxxx-xxxx-xxxx
better work in linux, im running it on a Raspberry Pi
turned the onboard IR off, let it roll w/external IR Cannon.. with as sensitive as this thing is I was getting alot of dust/sprites from the onboard IR so this cleans it up very well and will make using tripwire on this camera much more reliable.
the reflector on the car also dont flare up the lens, since this monitors parking I always intended on using external illumination.. Pulling ~18.4W right now so this is a bit more IR than is built in.
Internal IR sucks. Once you turn it off and have enough external light you'll hate anything with internal IR especially if you rely on motion alerts.
I admit I lol'doh fuck!
here he is, been trying to catch this fucker but could never get a good ID.. think I finally got it though, fuckin hippie better watch out now..]
this camera does allow both heat map and IVS to be enabled at same time.. thats nice, though I would prefer to have people counting and IVS.
View attachment 13931 View attachment 13932
it shows where the most activity is; its most usefull for retail stores as it lets you know how people are flowing down isles and help you decide where to place products for best results.
I'm seeing about 5.5W idle on my bench, so the heater and IR are off
