bob2701
Is it loud?
It does have a fan so it is not silent, but not loud at all.
Is it loud?
According to AliExpress you've moved ~120 cameras through your two store fronts so far, and thats not including side channel paypal orders.. all the other listings on Ali for this camera have moved a mere 16 units combined.. now that you have decent stocks and faster turn around I'd only expect that to grow faster than before.
We have a large audience here and this is why the elders of this forum wont tolerate members suggesting junk.. when a model becomes popular on these boards alot of cameras get sold and we dont want or need another Huisun MiniPTZ fiasco. (Over Hyped and then High Failure Rates started getting reported), Im confident Dahua wont let us down, its not there modus operandi.
What bank do you use? Was it a large purchase? I bought one starlight turret and it went through my bank just fine.
Your fortunate, on paper they looked like the perfect lil home PTZ.. small w/good optics.. but every time there's been a heatwave and/or cold snap we've gotten several hardware failures.. also the firmware is crap and they brick themsleves when they get configured in certain ways.I missed that fiasco.![]()
seems like most of our users whom got one didnt manage to achieve a full year of use before they were trashed.. some people been lucky, but far too many have felt the burn.. The popular member whom introduced the junk on the forums got banned when his ego would not allow him to admit his cherished camera was a piece of shit.
My dad's IPC-HDW5231R-Z arrived yesterday from Andy / BEC and we put it up today watching a gate. Here are snapshots at both extremes of the zoom range.
If you mount these flat, will the lens rotate and point 90 degrees to the wall?
the mount will allow it yes, but the IR Reflection from installing it like that will ruin the image at night.. you dont want any close up walls and stuff in view, the IR is pretty wide angle and with as light sensitive as this camera is installation may be a little tricky.. always test both day and night before actually installing.
Yeah I had these cams tweaked down to not kill the current computer but now I will have horse power@hmjgriffon variable can save quite a bit of disk space if its a less important camera or your relying on onboard SD storage to get off the ground, but yeah for primary ID cameras I typically run fixed and near highest bitrate for max quality.. Substreams I run at variable as it helps alot when viewing remotely and locally with a grid of cams.
@tygger, PFA137 Junction box.. @EMPIRETECANDY keeps some in stock if you need em.
since mine's not on primary ID duty its running: 15FPS/VBR/Quality 6/6656Kbps (basically max for VBR at this framerate).. Observed bitrate in SmartPSS right now in daytime is ~3300Kbps
I'm very pleased with the quality at these settings, my indoor Starlight is basically running at the same thing.
