MacFun
Indeed. Recommend a junction box PFA137 or PFB203W wall mount - the wall mount is better imho for water resistance. Other options are pushing the wiring back into the wall or soffit - or surface mounting the wiring ( which may make it easy for someone to cut if they can reach it - so I don't like that option as much )
The junction box will not help with water resistance but if you need the room for your wiring harness you need the room. I personally will be mounting to a soffit and other locations where the wiring can be tucked into the hole under the cam. This turret cam has a face only a mother could love.... the low-profile the better.
Robert
